Hi all...probably not the first to ask about this but couldn't find an answer in the forum.
I have a Beneteau First325 and am replacing depth, speed, and wind instruments. Pulled old thru-hull transducers and found that the new transducers are 1/8" smaller in diameter. Was considering building out the extra 1/8" by laying layers of fiberglass and resin on inside of hole walls...figured a few layers would probably build out the 1/8" I need. I'll be using the West Marine sealant(their version of 3m 4200) to seal the flange to the underside the boat and then fill the threads of the transducers with the sealant as per instructions.
Thoughts?
Thoughts?
