Hi All,
I recently purchased a 1979 ODay 30 with a folding prop and am currently in the process of refitting it back to (what I believe) it's original 2 blade prop and have a a few questions and looking for help/insights. They are:
1. The prop that has been stored on the boat (and I believe original) is a Michigan Sailor 16RH-9. Can any one confirm that this is or fits into the specs of the original prop?
2. When 'test-fitting" the prop yesterday the prop slid up the shaft to almost touching the strut and had a bit of play. I have heard that a bit of play in the prop is normal for this boat and wanted to confirm if this is the case and should the prop be so close to the strut?
Again, any insights/ODay expertise will be greatly appreciated. Cheers...PK
