1 - 13 of 13 Posts
I just bought a 1975 chrysler c22. It came with 5 sails, of which all are stained and look hideous. Its not rust stains but something else???...not sure what it is...brown in color. Ive tried commet, barkeepers, and a couple different rust removers with no luck. Any advice???
LOL,
Try the experts at sailcare.
They will examine them and let you know exactly where you stand, but like Solomons has said, chances are they are blown out.
midlife crisis member
Fill the tub with water that you can just barely put you hands in without getting burnt. Add a scoop or two of tide. Insert sail. Swish the sail around every 15 minutes or so for an hour. Add more hot water. repeat swishing every 15 minutes for another hour. Drain tub. You will be surprised how dirty the water is. Add more hottish water. Swish sail around, drain. Add water one more time. swish and drain. Hang sail on the clothes line or over a fence and hose off (both sides). Let dry.
They should be much cleaner now. I have done this twice. Made a huge difference.
Eric
Do what AllThumbs says, but also put something heavy (bucket of water, for example) on them. Dacron floats. Also, real TSP from a hardware store works very well and won't harm the dacron. Do not use bleach, whatever minimal stiffness these sails have will disappear. Also, Dacron won't absorb Rit type dye. It has to be added in the manufacturing process. But best suggestion of all, get a quote from FX Sails or some such. New sails will make your boat better in every way.
1 - 13 of 13 Posts
