1 - 20 of 29 Posts
Corsair 24
hey dudes...Im trying my best to get opencpn to work for my area...and no matter what I do I only get part 3 of the 3 part cm93 charts to appear
each part is around 700mb
apparently thats everything from 45 degrees lat and up...
I would love everything from that lat DOWN...
those of you using opencpn, what am I doing wrong?
I have used winrar and zip7 for the uncompressing and folders...I just cant seem to get opencpn to do anything else...
are there any ways to get specific charts for my area without downloading the cm93 charts?
alternatively im looking for blue chart chips for my garmin 76cx if anybody is up for charity:D
beers and dinner on me at the restaurant if you come on down this fall...
thanks
christian
Corsair 24
Discussion Starter · #3 ·
yes that would be a great start...Im not having any luck with free methods...
i.e opncpn or others
I downloaded mapsource for plotting on my pc my routes then uploading to my garmin
however that isnt exactly what I need...
I heard the blue charts are the way to go for garmin stuff, so maybe someone has one lying around...
Ive always done paper charts and plotting but I only have some paper charts for these areas so a backup would be great on the handheld
thanks
Christain,
It is tempting to suggest you move to the north ... :)
I take it you have downloaded CM93. Now, there are some things to consider:
- OpenCPN only works with CM93 v2 (this you know already).
- CM93 v2 exists in some different issues, dated from 1990-ies and to at least 2012. There are some differences, the earlier came in many zones, separated in different packages, most usual was 3 packages of about 700 MB each (700 MB is also what fills a normal CD ....). Later issues is in "one set".
- When linking OpenCPN to CM93 earlier versions one can only link to one of the sets, so you must know in advance which set. This you can usually see on the Zone map which use to be placed in the first set.
- some claim the later versions of CM93v2 lacks detail as the total file size is smaller than the earlier ones. In my sailing waters I have not noticed any real difference, but I have read that in some distant waters there are issues. You have to test and compare, if you really want to know (boring job).
- OpenCPN + CM93 is avery good working combination. Add in whatever you want, as GPS, AP, AIS and so on. But never rely 100% on this.
- In many areas one can download free electronic charts in a format that works for OpenCPN (S57 I think). Google and you will find. One such area is US. :)
I like OpenCPN a lot, it has very high quality, works fine with scanned charts (rendered? raster?) and with some other open formats. But it is "pc" based, works on pc/mac/Linux. Works lousy on Android, one has to do a lot of nasty things.
Anyhow, this means this is nothing for the cockpit. You will need a real plotter. (Sorry, time for pc based navigation is over).
/J
Corsair 24
Discussion Starter · #5 ·
thanks jaramaz...yes I have the 3 pack cm93 charts...but no matter what I do only 1 part of the 3 shows up
I tried removing the other 2 from the directories and even then I only get the background map
when I was cruising on my boat 10-15 years ago I used captains software and it worked just fine, off a dell pc.
I use a handheld in the cockpit always just to reference my paper charts
what I would like though is a backup pc plotter that is down inside
my other option is using the handheld as a plotter and keeping my paper chart updated down below
so if anybody has blue charts for garmin that would work better! jajaja
Once known as Hartley18
Christian, it's a bit odd you only see 1 of 3 parts.. Just to check, when you go to to "Options|Charts" are you seeing all three parts added to the list?
I'm not sure what directory structure you are working with, but I would place each part in a separate directory labelled "Part 1", etc., add each directory to the charts list individually, then check "Force database rebuild" and click "OK".
If you still don't see the other parts where you're expecting them to be, it could be a chart calibration issue (ie. the charts are there - just not where you're expecting them to be!) The bar at the bottom of the main screen shows which chart you're looking at.
Hope that helps :)
Christian,
You may have an error in the files you have downloaded. Not uncommon ..
Put away the CM93 you have downloaded in a completely other directory and un-register in OpenCPN.
Find another one at another site, download, un-zip (or whatever) look into the directories.
The directory tree of CM93 2009 (as an example) looks like
folder CM93_May2009_Zone_1-2
folder CM93_May2009_Zone_3-4-5-6-7-9
folder CM93_May2009_Zone_8
and then there are 3 pictures illustrating CM93 zones etc.
(names could vary, but structure should be like this
When opening any of the above folders they contain only one folder called CM93 (which then have sub-folders). This is as the original CM93 software (similar to OpenCPN) required the data base to be called CM93.
The first folder contains 540 MB, 7554 files and 507 folders. The others are probably similar, this is to give you an order of magnitude.
/J
Corsair 24
Discussion Starter · #9 ·
Hope that helps :)
I should specify I dont see them on the chart! I see them in the directories well, all complete with subfolders and dates etc...
regarding the global background map...on my part 3 its automatically there or shows up as soon as I scroll up to the north...if I go back down south nothing...
I sometimes see a brown bar instead of part 3 yellow bar and it shows the map, however it has less details in the bar, just scale and that its mercator or something
however nothing shows up on the backround map
I tried taking off part 3 so I could individually "see" part 1 or 2 and what happens there is part 3 dissapear but again I dont see any charts for part 2 or 1.
it has to be "there" but I dont know how to get them...
they downloaded fine...
Corsair 24
Discussion Starter · #10 ·
You probably know this but when you add new charts you have to tell open cpn to redefine its database. Go to the tools menu and then the charts tab and at the bottom of the page you will see the check boxes.
no I DONT know that
can you explain what redefine means...maybe thats what Im missing:)
Corsair 24
Discussion Starter · #11 ·
Christian,
/J
maybe I dont have 2009 version...
The cm93 charts I downloaded came in 3 parts...each part has a subfolder like you say...just like ot shows there
however the name only says part 1, part 2, part 3, I have no detail of zones...on any of the parts...
maybe mine is an outdated version? and only part 3 works
can someone explain how to redefine the charts? that mitch was talking about?
when you have linked to a folder, in OpenCPN, you also have to OpenCPN to update its registers.
In the very same OpenCPN meny where you add new links, there is also, at the very bottum, two (2) boxes:
- search for new charts ....
- read in all new charts from beginning
(for some reason I got a translated version on this computer, so try to understand the meaning here, not on the letter).
In summary:
either you
- have a map data base which is corrupted, then you should get a new one (as I proposed earlier; do not get hooked on details here), or
- you have an OPenCPN handling issue.
start in any of these ends. Your problem is easy ... don't despair.
/J
Corsair 24
Discussion Starter · #13 ·
thanks man...Ill keep trying
btw thoe boxes you say translate on my opencpan to
force database rebuild
and search for new charts
I do that and its a quick 1 second search and it just goes back to normal
nothing "happens"
what settings are you guys using for the charts?
mariners standard, other, base?
cheers
Christian, FWIW I think you are doing everything correctly - it's a chart calibration/compatibility issue.
To check for a calibration issue, load only 1 of the "non-working" parts (and no other charts) "Force database rebuild" and then zoom right out. Look for any area of the background map that looks like it has a chart there. If you zoom in on that area the name of the chart should appear in the bar at the bottom.
If it's a version issue, you won't see anything at all.. but I would expect the file structure of the non-working parts to look different (or have different filenames/extensions) to the part that works.
It's possible (but hopefully not the case) that the 3 "parts" you have all refer to the same latitude and are not what you think.. Since electronic charts are very scarce for this part of the world, I've come across that before.
Good luck :)
Over Hill Sailing Club
I've tried using Open CPN a couple of times without much luck. Either the charts won't load or they don't stitch, or I wind up with the dreaded blank stare, "program not responding." I know many sailors use it. I just have had no luck with it. Probably some sort of hardware vs software issue. I mostly use my little indestructible, reliable Garmin 376C and alternately, a laptop computer with Sailcruiser/CMap charts. As an additional option, I bought the Polar Navy program which seems to work very well and has never had a software crash. It is very reasonably priced and can use raster and vector charts. It's not a Beta version. That may be a solution for you. I don't know about you but I never want to wonder whether software is going to malfunction.
Reactions: christian.hess
Corsair 24
Discussion Starter · #16 ·
well yeah! for sure murphy I never rely on that solely
just wanted to give it a try...
might just have to save up a bit and pay for a program, or get some blue charts, etc...
I looked the polar navy stuff and it looked great...
cheers
OpenCPN is a good/high quality software, works on many platforms. No reason why it shouldn't work. At the same time, it accepts many different chart formats.
There is always the possibility to buy other software, they are then usually linked to one or two data formats.
CM93 is actually a version of CMap. CM93 is not for free, it is commercial charts. Those one can find for free download is then some kind of "pirate" version. Pirates are usually nasty in more than one way, so when downloading pirate data one often gets other data or software that one doesn't want.
Further, it is not unusual that such downloads are corrupted in one way or the other.
Thus, if there are problems with OpenCPN + CM93 this is likely to be found in the chart data base. If one wants to continue, the best thing is to totally discard the data base, and get a new one, from a better site.
On the pc I am writing this I have CM93 2011 (it is said). The file structure is simplified, all zones comes in one set. Total size ~1.4 GB. I just took a look on El Salvador - works fine, seems to be interesting sailing waters. Chart says mud mud and some further mud. And some sand :).
/J
Corsair 24
Discussion Starter · #19 ·
anchoring down here is the easiest...it will set the first time every time...very good suction
its actually a beatiful country...
anywhoo
I will try and download another version
question:
can I leave the part that works or should I get the complete different version?
cheers
1 - 20 of 29 Posts
