- Reaction score
- 2,087
router bits are expensive and have to be very sharp for you to not get tear out of what is usually expensive wood.
I saw this trick and tried it, and it works quite well! It doesn't make precision copy but is very close. 1/4" blade. and a small notch determines the "outside the line" cut depth.
my set up was not quite so elegant as this...
Fine Woodworking Image Popup
