1 - 3 of 3 Posts
Racor doesnt make specific 'engine mounted' fuel filters for engines. Engine mounted fuel filter cartridges as applied in specific engine manufacturers filter housings are usually supplied by the 'automotive filter' marketplace.
Go to ----- WIX Filters - Products Catalog Home ---> off highway equipment ---> select make = Perkins ---> sub make = marine engines ---> M20 etc. etc. .........
FUEL FILTER Part Number: 33386
UPC Number: 765809333864
Principle Application: Various Hitachi, Isuzu, Komatsu & Kubota Equipment, TCM Forklift, Toyota Forklifts
(10 Micron)
Applications
Style: Spin-On Fuel Filter
Service: Fuel
Type:
Media:
Height: 3.197
Outer Diameter Top: 3.234
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
Burst Pressure-PSI: 255
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
You can special order this particular engine filter at just about any automotive supply shop. Just use the Wix 33386 part Number as your 'cross reference' to all the other automotive filter manufacturers
1 - 3 of 3 Posts
