1 - 19 of 19 Posts
Unpaid Intern
Hi all,
I'm planning to rebed my chainplates--I asked a question previously for opinions on which sealant and got great help (thank you). The 3M 101 polysulfide sealant specs state that "service temperature" is °F -40 to 180. I assume that's once cured.
Does anyone know if there are temperature limitations for both application, and also subsequent temperatures while its curing (which can be 2 - 3 weeks)?
I ask because I might do this over the weekend--the highs will be in the mid-40s where the boat is in New England, but the lows could dip to the upper 20s. This cycle will continue over coming weeks as the temp creeps up. Will it cure properly in these conditions?
Thanks!
-J
Unpaid Intern
Discussion Starter · #4 ·
The application range for 3M 101, & all their other marine sealants, is 40f to 100f. I would not apply it if the temps will dip below 40 during the cure..
Thanks Main Sail. So quick question then--how does one rebed chainplates up north? Temps will be dipping below 40 degrees in New England well after the boat gets launched, which will be in about 4 weeks. That means I really need to rebed the chainplates now so it has several weeks to cure. But temps at night will be well below the 40s. Do people do this in the middle of summer instead? Seems that would be a problem too, since you'd have to take the boat out of comission for so long.
Thoughts? I really appreciate the help.
if you have power at the yard how about a small tent made of plastic around the chainplate and a 20 watt light bulb in the tent. if you want to avoid putting out light how about a simple heat tape for water pipes, they turn on at around 36 degrees.
put the poly on, wrap the chainplate with the heat tape. put a cardboard box with duct tape or some plastic to keep the heat in
edit here is one its 7 watts a foot turns on at 38 degrees. if they are longer than you want you can cut most of em down. just dip the end in liquid tape a few times to seal and insulate the end.
water pipe heating cable, insulation water, Easy Heat AHB-115 120-Volt 7-Watt Water Pipe Heating Tape - OneStopShopCatalog.com
Unpaid Intern
Discussion Starter · #6 · (Edited)
Not a bad idea, scottyt. Our boat currently has a cover with frame, so that helps. I'm wondering though if leaving something on like a light or the pipe heater, for weeks, would all right though. The boat is 300 miles away, so I can't check on it regularly, or even make sure that my power cable stays plugged in at the outlet that's about 75 feet away from the boat. Hmm...
Unpaid Intern
Discussion Starter · #7 ·
OK, so I just called 3M's Marine line (didn't know they had one) for technical support and asked them. They said the 3M 101 needs to be above 40 degrees when you're applying it, and ideally during the first 5 hours or so, for it to set properly. After that, if the temperature drops below 40 it's OK while it's curing. It will just slow down the cure time.
So the point is that I can apply it. We might STILL want to consider a heat source to warm it up and get it to cure faster. But according to 3M, the cold temperatures won't harm the bond, just the time to full cure.
So, with that being said, would you rebed your chainplates now, knowing that they had to be ready for use in a month, in New England? Highs are only around 50 up there now and probably won't be breaking 60 degrees before in a month. But if I wait to do this when it's warmer, the mast will be stepped, and that sounds like a huge PITA to me.
Certainly open to suggestions...
-J
Read Only
J
A Sabre 34 is a beautiful boat. Wouldn't you rather do the job right the first time and lose a little sailing time versus having to do the job again and lose a lot of sailing time. Just a thought.
Super Moderator
You..
You don't need to wait for them to fully cure before use. Remember the sealant is acting as only that, a "sealant", The mechanical fittings, or the nuts and bolts that hold the stanchion, require no cure for use.
Also beyond the point skimming over polysulfide is a moisture cure product meaning the more humidity it is exposed to the faster it will cure. You can use your boat fine minutes after bedding a stanchion provided you don't use the Don Casey two step method..;)
I usually wait until later in April to do bedding other wise I do them one at a time over the season but then again I am about 300 yard from my boat not 300 miles. If 3M says it's then go for it..
Unpaid Intern
Discussion Starter · #10 ·
Thanks Main Sail. I'd like to take advantage of the mast being out so I can do them all at once, plus I'd like to inspect them before the coastal sail home. Not sure if you realized I'm asking about chainplate rebedding, not stanchion, though not sure if it matters.
Sooo, I could wait and do it in two weeks, when I'll be back up there again and it'll be warmer (but only 2 weeks from launch). OR, I can do it this weekend when it's cooler but 1 month from launch. What do you think?
Unpaid Intern
Discussion Starter · #12 ·
I just realized your in MD. You should be more than fine so I'd do it now. I thought you were talking about stanchions..:rolleyes:
Sorry Main Sail, while I'm in MD, the boat is in Connecticut. :( That's why I'm up there every two weeks, and it's a choice of this weekend or two weeks from now.
Does that change your opinion?
Unpaid Intern
Discussion Starter · #13 ·
Thanks!
I'm reviving my own thread, so this is OK, right? :D
Just wanted to send an update, since I rebedded my first chainplate this past weekend. While it wasn't cold out, it did help to search and read old posts and ask questions here on Sailnet, so thanks!
I used 3M 101 and had no problems. It appeared the core was sealed with epoxy, which is not factory, so it will be interesting to see if the other chainplates were also done.
The time-consuming part was getting the cover off the deck, and also cleaning it and the slot area. It had a lot of sealant in there. But the rebedding was a snap once everything was clean.
Anyway, here's a pic, before fully cleaning the chainplate up (so there's a little sealant residue still on there, but you get the idea). I hope it holds up!
-J
Irrationally Exuberant
Nice, J. And very nice that a PO sealed your core there. Bodes well for other hardware--and tells you something about the quality of care.:)
Looking good Joz.
-J
Unpaid Intern
Discussion Starter · #16 ·
Thanks sailingdog and arf145. Yeah, it's a good sign that it was sealed. It wasn't done the way I'd do it, but you can't have everything. :) I'll be interested to see if they've all been done this way.
Two weeks before launch should be find from a curing standpoint. Just make sure you leave yourself enough time so that if something goes wrong, you'll have time to fix it.
It seems that every time I touch anything on my boat, something goes wrong :(
midlife crisis member
I re-bed all my stuff with 3M 101 when it was getting cold at night and all was well too. I think the 40 degrees for application is mostly so it's not too thick (viscous) to get it out of the tube.
Eric
1 - 19 of 19 Posts
