1 - 3 of 3 Posts
Hi All,
I know the title of this thread is going to get several "here we go again" for such a common issue. But here it is anyway. I have 6 Beckson port lights that leaked between the rubber gasket and the plastic window. The inside and outside frames are water tight. So I replaced all the gaskets and then found I had to loosen up the cams ALOT to even get the windows closed. No big, as the gaskets are new and thick. Four months after replacement, I got tired of feeling like I was going to break a cam, so I loosened one window up to experiment and it leaked. Is there some sort of gasket lubricant that will help with the closing and sealing? Thanks.
Dave
no longer reading SailNet
Silicon grease is good stuff.
Those Beckson seals can be a PITA. They do start to compress eventually and opening and closing the port gets easier. My boat still has the thumbscrews (the cams are an "upgrade") and I think they make it a bit easier to work with the new gaskets. I don't know if switching back to the thumbscrews is an option for you.
1 - 3 of 3 Posts
