1 - 14 of 14 Posts
This electric block is in the v-birth.
Any idea what it does?
Boat is german made Dehler 29 2021
The wires at the bottom are just loops. Two loops where both ends enter the block.
Bicycle tire Networking cables Purple Audio equipment Electrical wiring
Light Sports equipment Electrical wiring Cable Electrical supply
Reactions: unrockbar
It looks like one of the (brown?) wires has a yellow identifier on it. Can you check behind your breaker panel and find its companion and which breaker it's connected to?
I'm going to guess and say nav lights.
Contest 36s
Looks like a terminal block for all the low voltage 12v wiring... nav lights, windlass switch (maybe)... fan (maybe)... USB charging port (maybe)...
It's going to be interesting to hear what it's for. There are twelve wires on that block, not including the jumpers. Not sure why either a bow thruster or windlass would need so many. My theory was something that was on the same circuit, with several appliances (ie lights)
Discussion Starter · #8 ·
I have no bow thruster. The windless was replaced and the guy who did it did not mess with that block.
The only thing left is cabin lights and nav lights.
It seems like a lot of wires for nav lights. I think I will count the cabin lights and see if I can figure it out.
I have a separate switch for forward, center, and aft lights. I'm thinking this is the distribution hub for the forward cabin lights.
I'm afraid to mess with it as it is working.
Contest 36s
You can and probably should identity where the wires go. Disconnect one and try each light to see if they work. Repeat until you have identified what each wire does. Put a VOM and determine which wires are pos and which are neg. Label everything or make a drawing or both.
Discussion Starter · #10 ·
for sure
Suspense. When are we going to learn the answer? A multi meter on the incoming power and playing with the breakers would do it, if that yellow tag doesn't.
Discussion Starter · #14 ·
It's going to take a while as my wife is using that cabin for a few days and I don't want to take a chance of breaking something. I'm almost certain it is the four cabin lights.
Reactions: SanderO
1 - 14 of 14 Posts
