101 - 120 of 127 Posts
Okay, just worked my way all the way through this very useful thread. Our contribution:
Harbor Freight Multi-Function Tool. We're getting to the end (thank the Gods) of a complete deck replacement, and use this tool fairly continuously, every day. We got two, eventually, and got the $5 extended warranty with each. With two we can both work at the same time, keep them set up with different blades, or with blades set up at different angles. Also if one croaks, you still have the other. They work great (though loud, I use ear plugs) and are about a tenth of the cost of the Fein Multi-Tool.
i totally agree on the multi tool, absolutely indispensable. i thought it paid for itself the first time i used it. also the finger sanding attachment can get to places you would not believe, dramatically reduces sanding time.
Rust removal
Found a spray rust remover called "Ready Strip" by Sunnyside Products at my local hardware store. Contains Oxalic and Citric Acids. I've tried similar products before, but this stuff did a good job on rust stains nothing else worked on. 32 oz cost less than $6.00! It's odor free, and claims to be environmentally safe.
"Sparkie"
Max Prop (PYI) is now on my list of preferred vendors. I worked with Fred Hutchison on parts for a prop and he took all the necessary time to make sure I was getting what I needed. They seem like a good company to do business with!
DD
leave my member alone
Has any gotten, or know someone who as sail from FX sails online. Are they any good. They would be for a Hunter so I'm not worried about sizing issues. Any toughts?
I have tried many brands of ablative paints for my sailboats the past dozen years. In the Bronx, NY, there is a constant coating of brine shrimp. I would dive down and clean the bottom almost every other week by August/September as the water warmed up.This past winter I found an article in Practical Sailor. They raved about Blue Water Marine Paint Copper Pro SCX 67 Boosted Ablative Paint. It is almost September, and I have done one quick cleaning all season. I will never try another bottom paint!!!
(snippage) They work great (though loud, I use ear plugs) and are about a tenth of the cost of the Fein Multi-Tool.
That's a very important tip about the earplugs. While you're at Harbor Freight, HD, whereever, pick up a box of the foam ear plugs. Be sure to use them right: you have to roll them between finger and thumb to compress them, then insert them INTO your ear canal. It will tickle when they expand, but that's the ONLY way they will work. If the end of the plug is sticking out past your ear, they will not protect your hearing!
3M Finesse applied with a Milwaukee right angel polishing motor will absolutely cut thru flat sun-faded gel coat and get it back to a gloss with color. Don't overdo it as there is a limit to how much gel coat you can remove.
PB Buster or Kroil are two of the best penetrants made for your worst fastener that's stuck. WD40 is on every shelf so you'll have to look at NAPA or some high end stores to find them.
I don't discuss my member
Gill safety knife.
Wish I could've reviewed the knife but the sheath held so poorly it would drop the knife if there was a stiff breeze. Wrote to gill, no response, no change in design. Horrible retention.
Gill safety knife.
You're missing the point (no pun intended!). The knife instantly falls out of it's sheath into the drink. Then...there is no way you can hurt yourself with it. Can't get any "safer" than that!
Seriously, maybe your's was defective (looks like it has a mechanical release). If West Marine carries them (and IF you still have it!), I would check them out there. They would probably exchange it. No excuse for Gill not responding though! Unfortunately, poor customer service (or NO customer service!) seems more common now days.
Led spotlight
Edit: See post 113 before buying this light!
Bought this Led spot light at Lowe's for $39. It's rechargeable, is compact (it's body is about the size of my hand), waterproof (it floats beam up), has a bright beam for a small light and has adjustable intensity to save power. The on/off adjustment system looks like a potential weak link to me, but user reviews are good. A nice addition to my boat.
Shop Stanley Waterproof LED Spotlight Flashlight at Lowes.com
BTW: This thread has proved useful and popular. Having just reviewed it again, I agree with early posts that called for a product review forum. It would be even more useful. Categories could include: Tools, Paints, Cleaning products, Electronics, Lighting, etc. The pages of this thread should provide a useful guide.
Had 2 of those lights, bought at Costco in Canada for $29.99 each. Great ergonomics, size, range, brightness. BUT neither one would recharge after about 4 months. Used them when showing houses, never had them wet. I'm rating them 0 out of 5 stars.
Sundance 23
I bought one of these Stanley lights last year. Works great, no problems with on/off, really holds a charge, and is very bright.
Oh no...say it ain't so!
Yikes! I was afraid of that, but thought battery technology had advanced enough to avoid that old problem. I understand that Costco has such volume, that name brands manufacture products "especially" for them to achieve their price points (hence, the 33% discount). Don't know if it's true, but given the favorable reviews I've seen on the light, including one in this thread, maybe thats the case. If not, I'll be sure to post about it, just after I return the light to Lowe's!
Edit: Sure enough....The light no longer takes a charge. Called Stanley and they said I could return it (of course). Asked the rep it the light was problematic. He said "no...I have one myself". Yeah...right! Too bad. Other than the fact it no longer works, it's a nice light!
Re: Product Reviews-SNADS
Finally getting around to installing the snaps for my cockpit cushions. After thinking twice about drilling, even a small hole for the metal snap/screw I decided to use the 3m SNAD. It's plastic, has a great adhesive with no holes to drill. I used the male SNAP for the locker lids and metal female snaps for the strap on the cockpit cushions. So far, so good! They are holding very well!
Do you have a link to the product? I checked Google and the 3M site and snaps snaps for everything from dentures to stethoscopes.
Boomkicker...
Two thumbs up
Installed easily and I no longer fight with my backstay mounted topping lift. An added bunis is no more ducking at anchor
past Caribbean cruiser
I have an '86 Peterson 46 that is fitted with Adkins Hoyle hatches and port lights. For the life of this boat these have been superior products, well constructed with little in design left to be desired. recently I went to replace the galley hatch as the opening portion developed a crack in the aluminum casting from metal fatigue from the spring. It only lasted 27 years! Wishing to replace with like brand I ordered a new hatch from AH as they would not replace the broken part only. It is a 12"x 17" hatch, replacement was $1275.00, which I thought was a bit high but as I could not fault the quality ordered the replacement. What I received was not the quality present on the boat and AH gladly accepted return with promise of a suitable replacement. Having just received the replacement and being again dissatisfied with its quality, called AH and spoke to Eric. He indicated that he had himself inspected the unit before shipment and found it acceptable. the issues are the castings which are of a much rougher finish and overall poorer in detail, the hinge bar holes were inaccurately drilled making the hatch and base misaligned upon meeting, the hatch is "reversible which is an additional charge but the support bar hole was not tapped. When I informed AH about the deficiencies I was informed that this was "as good as it gets" and that I was welcome to return the unit but that there was no point in replacing as another would be no better. I will likely keep the unit as I wish to keep uniformity in my components but I wanted to let folks know that we cannot rely on the quality of AH products as we have in the past. ERic at AH told me it was no longer profitable to invest the labor to make the same quality product as is on my 27 year old boat. And that is at $1275 for a 12x17 hatch.
so as a gear review thread just thought I would put this out there. The people were polite and accommodating and willing to accept return so I cannot fault them for that but they are apparently no longer capable of producing the quality that is their reputation.
I had similar response and attitude from Eric over saloon and head hatch lenses and also opening port gaskets & fasteners. For two small lenses, 3/8" gasket & 6 2-1/2 socket head screws over $600. I located everything needed elsewhere for less than $200. They obviously don't know how their competitors produce a better product at a profit. But it's the attitude that less is better when boats cost more, production volume is lower, and the higher end buyer is expecting more. You would think tooling quality for castings would have improved, not gotten worse. A&H covered a huge market in their day, but it sounds like their days could be numbered.
