1 - 4 of 4 Posts
My boat is in fresh water, Lake Michigan. Can anyone tell me what the corrosion is as seen in the attached pictures? Does this look like galvanic corrosion. I had the boat yard put on Magnesium sacrificial anodes prior to launch last year. I can rum my finger across it and some comes off.
Should I remove this stuff with sandpaper or anything else like that? How can I prevent it from coming back or getting worse?
Thanks for the help.
Are there 'pits' into the metal underneath this accretion when you clean it?
If no, then the strongest possibility is simply bacterial/microorganism, etc. colonies and/or the 'excretions' of such colonies growing on the shafting. This happens a lot to bare metal underwater surfaces in fresh water, especially where 'slime', and other 'soft growth' etc. buildup is heavy.
IF you see that the actual surface is being attacked/etched by such growth, then consider to use a bottom paint on the shaft (one that is compatible with the metal shafting) to prevent 'whatever' is attaching and growing and is using the metal surface as a nutrient source.
Discussion Starter · #3 ·
Thanks, this makes sense. There is quite a bit of slim where I am. There's no pitting; comes off pretty easily. I noticed, in the boat yard, that quite a few have this issue. And, some don't. Maybe I'll ask the boat yard if there is a product I could use.
Sandpaper. Monthly. 120 grit wet/dry. You are not going to hurt the shaft even with 20 years of sanding.
Reactions: gbgreen59
1 - 4 of 4 Posts
