propane solenoid switch
1 reading
3.9K views 26 replies 16 participants last post by  SanderO
#1 ·
(first boat I've owned with propane) My boat has a breaker on the main panel for the propane solenoid. And another breaker on a dedicated panel in the galley, arms reach from the stove. Both need to be switched on to to open the solenoid.
the main panel is across the cabin from the galley.
Why 2 breakers?
#3 ·
Yes, that makes perfect sense.
So followup ... any safety (or other) implications in deleting one of these breakers and leaving only one place to turn the propane on and off?
#4 · (Edited)
Of the boats I've seen with propane stoves, there's only been the valve on the tank and the solenoid switch near the stove. I haven't seen a separate breaker for it on the main panel. Use the solenoid switch when you need to cook, and screw the valve shut when you leave the boat.
Being able to quickly reach the switch from the galley is a key safety element (and I suspect is also in various standards that your insurance company expects you to be in compliance with).
#7 ·
Beign able to quickly reach the switch from the galley is a key safety element (and I suspect is also in various standards that your insurance company might expect you to be in compliance with).
A friends Mariner 39 has such a dedicated breaker on the main panel and a switch (not sure if it’s fused) in the galley. Plus the tank valve. I agree about not removing the galley switch. Makes it easy to bleed the line when you’re done cooking.
#6 ·
I'm guessing the one near the stove is there as an quick emergency fuel cutoff. Not sure if it's necessary or not. I had CNG.
The boat I deliver every year has a dedicated breaker on the main DC Panel and a large amber indicator light near the stove. I find that set-up useful.
#10 ·
We have a similar setup with a switch on the main board for the propane solenoid and another near the stove. Obviously also a hand valve on the tank. Seems like a good way to make sure you know the propane is on because it won't run without them both open.
#14 ·
My boat has a breaker on the DC panel (as there should be) to protect the wiring. And there is an on/off switch in the galley with fuse. I wouldn't have it any other way.
Reactions: bristol299bob
#20 ·
The surveyor in my recent boat purchase made a comment that the ABYC has a recommendation on a switch being located "near" the stove, and the boat in question only had a breaker at the panel. The panel was athwartship of the stove, so the argument was that it was "near" enough. If I had a stove fire, I'd be happy to not reach for a switch near the stove, so being across the boat from the flame seems safer.
#21 ·
One of the benefits of a dedicated switch "near the stove" is that its really quick to find in an emergency as typically there are no other switch/breakers in its immediate vicinity. near the stove as I recall has to be close enough that its pretty obvious what it does but far enough away as to not require the operator to have to reach over flames to use. Typically that will mean to the side or behind the operator. just ideally not burried in a panel of 24+ breakers
#27 ·
Picked up the propane tank but didn't bother to have it filled. Let the next owner do that.
Started the engine for 1st time after winter.... started right up... ran well. Everything on board was OK. Next visit I will fill water tanks and do a Spring cleaning.
