21 - 28 of 28 Posts
Freedom Chip Counter
If anyone is in need of a "boat sitter" on the SE coast of Florida, let me know! I'd be happy to do it on an as needed basis for the cost of time and mileage. Send a PM if interested.
Dave
If you have solar why can't you turn the batts off and let a bilge pump wired directly to the batts drain the water? I realize keel stepped masts get water into the boat and that needs to be removed.
Deck stepped should have no leaks and may not need to leave the bilge pump on. Solar should keep the batts topped up.
If the boat gets hit by lightning your solar and bilge pumps are likely toast.
Sent from my moto x4 using Tapatalk
A gallon of Simple Green never hurt anything and it smells good.
I use it aboard, especially to clean up grease or oil. I understand, however, if left to stand for extended periods, it will corrode some metals. Aluminum in particular. You are cautioned not to use it on aircraft, with aluminum structures, and not to leave it on any aluminum for more than 10 minutes, without thoroughly rinsing. Simple Green even developed a special formula for aircraft, as a result. The Air Force banned the original formula.
As long as you rinse well or keep it off aluminum, it's good stuff.
21 - 28 of 28 Posts
