Hi
I've seen some boats fitted with about 3-4 ft long approximately 1-1.5 inch PVC pipes around shrouds and i guess for ease of jib/genoa sheets sliding across them.
i was planning on fitting same on my boat but am unsure whether to cut the pipes along the length of pipe and slide them on or remove the shroud from the deck shroud fitting and insert the shroud into the pipe. I am somewhat reluctant loosening the rigging? would this affect the mast integrity? i will of course fit the top cap on the pipe to center the shroud wire inside the pipe and keep the bottom open to allow draining and prevent the dirt from accumulating.
Any suggestions are welcome and any other alternatives to improve tacking / jibing to prevent sheets from getting stuck.
petar
petar
