Hoping this is the best place to ask this question.
We are refitting a 1972 Albin Ballad, which is a Swedish IOR boat with pinched ends and typically cramped interior. Our version had no quarterbeth but did have outboard pilot berths, which even I (a skinny rock climber) found difficult to access. My partner, no way. The salon benches will make perfectly adequate sea berths underway. At rest, we'd like to convert the settees into a true athwartships queen bed. They have been redesigned for the purpose, with a consistent 27" between the benches. The plan was to make some kind of platform that would hinge or slide out to span the gap, then we would arrange the cushions in some clever way to make a big mattress. This is sorta where we are:
Trouble is stowing the plank(s) w/out messing up access to the stuff under the settees. While mocking it up, I had to use two 27x30" pieces of plywood rather than one, and they are awkward to install w/out painting yourself into the proverbial corner. So I was wondering -- have any of you cruisers made cushions with plywood on/in the bottoms of them? Then all we'd have to do is turn the things 90 degrees so the plywood bottoms span the gap, and the bed is made.
To get into the settee stowage, just lift up the cushion. No second piece of plywood to move aside.
Thoughts on rigid-bottomed cushions? Or should we just find a better place, like under the V-berth cushions, to stow the planks? Other ideas that have worked for you?
