Questions about Spot X & similar options
475 Views 13 Replies 7 Participants Last post by  Don L
I’m in the market for a satellite tracker with 2 way text communications & I need to purchase it fairly soon.
I’ve surfed around & read what I can find, including some older posts here, but I thought it would be prudent for me to ask about recent experiences with the latest & greatest versions of these things. I’ve looked at In Reach Mini, Zolio, and Bivy as well as the Spot devices. At this time, I think I want a Spot X, with the In Reach Mini being choice #2, but that is not engraved in stone if I come across new & compelling information.
I have a few specific questions about the Spot X.
1) I have found conflicting reports regarding it needing a clear view of the sky & an upright orientation to communicate effectively. What are the experiences of people here? Ideally, I’d like to mount it in the cabin & forget about it for a while.
2) I am told that on some versions of the Spot tracker, you need to restart it each morning. Is that the case with the Spot X? Or can I let it run for a week straight?
3) How difficult is it to set up the tracking on the website? Do I need a membership to something like Google Earth, or is everything included in my Spot subscription?
4) I have found conflicting information about the reliability of the Global Star network in different areas. I only intend to use it in the Caribbean and along the east coast of the US. The coverage map shows these areas as being good. Has anyone found dead spots in this region?
5) I am told that some versions of the Spot trackers give a confirmation when messages are sent & others do not. Is the Spot X able to provide conformations?
6) What are the differences between the basic subscription plan & the higher tier plan?
Does anyone have strong opinions about one sat message/tracker being better than the others?
Thanks,
Jim
See less See more
1 - 14 of 14 Posts
Hi,
I am a fairly long time user of SPOT. I started with the originally SPOT, then the SPOT X, and now I have the SPOT X Blue tooth.
Briefly - I am not happy with the SPOT X and if I were to do it over, I would buy a Garmin InReach product.
Longer version.
For TRACKING, SPOT X is fine. Some of the pings will miss, enough will make it so anyone following your progress will be able to see that you are making progress. For COMMUNICATING, I am very unhappy with the SPOT X. Messages are dropped, there is no notification that the message was sent.
The original SPOT tracker was fine, but the one way communication is that that useful for ME (someone who wants to receive information from the outside world). I upgraded to a SPOT X. First usage was an Around Long Island Regatta - a 200nm distance race in the atlantic ocean and Long island Sound. I set the SPOT X to send a track every 10 minutes and I connected my phone to it so I could send / receive messages when in the ocean and out of cell range. The SPOT X was attached to the mast so it had a clear, unobstructed view of the sky. Tracking was fine, most messages were sent / received (only a few were sent). A few hours before the race finish the SPOT X stopped working. After the race was complete, I brought the SPOT inside the cabin to charge the battery (thinking that was the reason it stopped working). I found that water was inside the unit and it was ruined. I was careful to have the power door closed, and it's gasketed to prevent water intruision. Anyway the SPOT was ruined. I contacted support and they sent me a new one, AND told me to leave it inside the cabin, and it will work just fine through fiberglass. The replacement unit was mounted inside, above a cabinet, safe and dry. This worked better (not failures) but on long trips too many messages are dropped. Last year I used on a trip home from Bermuda to NY and also on a trip from NY to Maine. A signiticant amount of messages are not delivered. On the Maine trip a friend of mine had his Garmin INreach unit. Every track and every message from that device was transmitted and received.
So my next device will be an inreach. I'll probably get the GPSMAP86 so I can retire my old Garmin 78SC.
The tracking stuff is easy to setup and use. it's very easy to create a share site and share with friends and family.
The differences between the various subscriptions are in how many messages you can send before you get charged. I have the lowest level plans because I'm not usually out of cell phone range for very long.
I'm doing a long distance race next weekend and my SPOT tracker will be on. I'll include the link before the race incase anyone wants to see it.
Barry
See less See more
  • Helpful
Reactions: 1
Well, we're big fans of Zoleo. Especially the dedicated email and SMS numbers AND the longer (900+ chars) messages for app-to-app messages.
The downside is tracking costs extra ~$6/mo (though their better plans are cheaper than InReach) and not to a webpage (this is unfortunate) . On the other hand, checkins to up to 5 addresses are unlimited and free.
Zoleo is currently having a sale (at least, here in Canada)
  • Helpful
Reactions: 1
I've got an InReach mini, I like for the following reasons:
(EDIT: I miss typed my original post ... I typed that I "had a problem with reception" at the nav desk. I meant that "I had no problem with reception" at the nav desk)
  • Its quite small, and can be installed out of the way. it's at the nav desk and I've had no problem with reception, anywhere below.
  • The user interface is mini and awkward! But I can connect with my phone and operate it with that "normal" interface.
  • Tracking is reliable. Spot users that I know users frequently complain of unreliable tracking.
  • Track can be shared with friends via web link
  • Weather and Marine Weather is available anywhere.
  • Helpful
Reactions: 1
If this is for your own boat why not consider Starlink? Obviously if you are changing boats often (deliveries etc) I fully understand)
I used Spot X as a back up on an Atlantic crossing and I found it very complicated to use and at some stage it stopped working. I certainly wouldn't recommend one.
On the same trip I used Iridium Go, which is truly portable compared to Starlink. I am sure there are many, many now for sale on the cheap as people have switched to Starlink.
As for tracker software, I am now using a free app mAIS excellent :) But you need internet first :)
Mark
  • Helpful
Reactions: 1
Thank you for all the replies.
I ended up getting the spot X. There were a few reasons for me doing that, despite people here & elsewhere telling me that the In Reach is the better unit.
One reason was that with the Spot X, I only need that one device to send & receive messages, as well as share my tracking. I prefer not to carry a cell phone when going offshore. Another reason was that some of the races in my area require a Spot tracker to be on board. I have no idea why they chose Spot, but that is their standard, so this opens some racing options for me.
I learned a few things when setting it up & starting to use it. First of all, if you want it to track for more than 24 hours straight without resetting the unit, that requires a more expensive subscription.
Second, text message latency has been about 5-10 minutes on average, each way. Position tracking seems to mostly be on time. If you want tracking more often than every 10 minutes, that requires a more expensive service plan. The fastest time interval available is 2.5 minutes. Faster times reduce battery life.
You can program how often it checks for waiting messages. Intervals are the same as above, or you can check them manually, by pushing a button. So far, no messages have been lost, but I haven't sent that many yet & I'm in a well populated area of the US mainland.
It came with a comm/charging cord that has some ferrite chokes on it. Some chargers will charge it from a standard cord. Others will not. I haven't tried the bad chargers with the factory cord yet. The connection is micro USB.
The set up on the website was not intuitive for me, but they had phone support people who were willing to walk me through it. With a little help, things came together pretty quickly. The tracking software seems to be set up more for tracking fleets of trucks, than boats, but it can work for us too.
My biggest gripe was not knowing about needing the more expensive service before I bought it. I'll know better for next time. It's still not that expensive. It costs less than the other options that are out there, both in hardware cost & subscription fees.
I plan to field test it on a delivery in a few weeks.
See less See more
Reactions: 1
Hey,
I starting a 130nm distance race Friday afternoon. My SpotX will be on and transmitting every 10 minutes. If anyone is interested in seeing how it works, where we go, etc., this is the link to my shared page
My start time is 3:00PM Friday. I will leave my home port around 10:00AM, and I'll start the tracking then.
Barry
Reactions: 1
Hey,
Barry
Hi Barry,
if its possible, could you do a reply to this thread when you are about to turn it on/leave home and we can watch your race :)
We are underway
Hi Bill.... you are in Israel.
See less See more
Other way around it looks like by the "spot" timestamps. Starting from near Mt. Sinai at 10:09:25 and getting to south of Stamford at 13:38:26 before backing out a little. So it looked like it skipped the 11:09 update and then 2 updates (or 1 was very delayed) between 12:50 and 13:17.
Not entirely "Spot on"... :unsure:
~~ Red
Reactions: 1
How often is it meant to update?
I have never used Spot X before, but Barry mentioned 10 minute updates earlier:
And as I recall, something about more frequent updates with a more expensive subscription.
~~ Red
Reactions: 1
I have a garmin in Reach (sport i think) and have liked it just fine. I have friends I track, some with the InReach and some with the Spot. I have a harder time getting the tracking on the Spot to work. That is all I can input
1 - 14 of 14 Posts
