Hi!
I just joined this forum i hope some of you could help me with some information.
I recently acquired a 1978 Ranger 22 Sailboat. It is mostly there but it is still a restoration jobs. I'm having a hard time finding any information to help me on my efforts. Here are some of the questions I have, I'm hoping doe of you out there may have the answers or could direct me to someone who knows. So here it goes:
1. The previous owner of the boat ran over the back stay with a lawn mower. This boat has a shorter back stay that ends in a block & tackle setup to adjust the angle of the mast. I need to know how long is the Backstay for this boat so I can replace it with the appropriate length.
2. The windows were removed, but I have the original. Do these just get attached to the fiberglass directly? If so what should I be using to do this? There are no frames on this windows.
3. The keel iix fine. The previous owner had the stainless steel bracket that is mounted on the keel to lift the keel. Is this something you leave permanently attached on you only use it for lifting the keel? I have seen pictures of of the boat being lifted with a single steel cable attached to the keel. Not sure I feel comfortable with that. Any thoughts on this?
4. Can the hull on this support support the weight of the keel suspended out of the water? I need to do some fiberglass repairs to the keel and I'm truing to figure out whether I can just raise the whole thing or I need to support the keel at all times. Any guidance on this?
5. Does anybody have pictures of what the inside of the keel section should look like?
6. If the bolts have been removed or were missing, while sitting on a trailer for 2 years. Should I drop the keel and reset it? Or should I just tighten the screws and call it a day? Any advise will be appreciated.
Well that is all I have for now. Thank you all for any information you care to share.
Jose
Jose
