1 - 8 of 8 Posts
I'm thinking about upgrading from the Raymarine ST2000 to something more robust like the EV-100 (which replaced the X-5 units recently). I sail an Olson 30, and I'm recently thinking of doing the Bermuda 1-2 in 2015, so the ST2000 will serve as backup only and I'll use the EV-100 as the primary unit. I'm trying to keep things reasonable (and simple), so spending $10,000 US is not in the budget. I also have an e7D as my primary chartplotter, but I'm not accustomed to using the AP as anything more than a dummy helmsman- at this point I'm only thinking of using it to hold a steady course, not maintain a heading based on apparent wind angles; reason being that I can't imagine a major wind shift occurring within a 20 minute window (my sleeping interval for the race) unless a squall is approaching, and I won't be sleeping anyway...
Also- would installing the EV-100 absolutely require connecting it via the Seatalk system? (which I currently haven't installed, since I have a very basic system and prefer to keep it that way, if possible).
Any help from anyone knowledgeable in these areas would be very helpful. I'm waiting to post a similar question to Sailing Anarchy until I get more useful and friendlier responses here... I'm also awaiting approval for posting on the Raymarine tech support site, which takes a while.
Ray
Sailor
I think it all comes down to how you use your AP. I have never connected my AP to my e7 and don't really see a benefit of doing so. I don't have a wind instrument so I can't set my AP to sail by wind angle but I don't think I'd want that feature??? I set my route on the plotter, set the boat on its course and engage the AP. If conditions change so I can't keep that course, I simply adjust.
To me; I'd just install the new AP from Raymarine, don't worry about connecting to seatalk or anything, and go on. I've heard good things about the EV pilots so I think your on the right track.
Tod
Discussion Starter · #3 · (Edited)
Thanks, Tod- I think the idea of the ap driving to a set apparent wind angle is that it might allow you to sleep a few minutes longer. I think I have to face the fact that each racer will be trying to "out-sleep the other guy"; philosophy being that the better rested skipper makes better and safer decisions. I may clarify this question over on SA to get an idea how significant that is-- I'd hate to lose much vmg just because I'm sleeping.. at least the sails won't be flogging!
no longer reading SailNet
The wind instrument has one other valuable feature. You can turn on a "don't jybe" feature on the autopilot that will allow you sail deep and follow a course up until the point where the boat is at risk of an accidental jybe. Then it will switch to following wind course. I could see this being very useful on the open ocean.
I use the integration between my autopilot and plotter fairly often for coastal cruising. It is handy being able to point to a destination (obviously not straight up wind) and say "go there". This is a little quicker than steering until my boat's course appears to intersect with the destination, then putting the pilot into auto (though I do that too).
Sailor
Very true! Good point, Alex
Mandolin, Bayfield 36 out of Rock Creek, Chesapeake Bay.
Sent from my iPhone using Tapatalk
1 - 8 of 8 Posts
