1 - 2 of 9 Posts
I currently have a single 6" cleat for the anchor, which is centered on the bow of my 24' yankee dolphin (1971). i feel that it's too small, and have a really hard time getting 2 lines over it when at dock as the base is too small to pass a bite of rope through it, so i have to do a cleat hitch.
it's your average cleat with 4 bolt, and a beefy backing plate.
i think i have a few options:
1. leave it alone and go sailing
2. install a larger cleat in the center, one with a larger opening at the base. this might be a good option if i can get one that matches the holes.
3. take it out, patch the holes, install 2 cleats on either side of the center line of the bow.
my main question is: does the anchor cleat have to have 4 bolts, or can i use one with only 2? i was thinking of using two 8" versions of this:
vvv.schaefermarine.com/press/chock_cleats0503.html
i like the schaefers cause there is a lot less exposed screws, making for better bedding and waterproofing.
sorry that i can't post a link yet...i'll start posting more!
thanks for your input!
Use the 4 bolt versions - MUCH stronger mounting. Use a big backing plate as well since it will hold your anchor line. I prefer Herreshoff style cleats.
Thanks for the input, i hadn't thought of a few things- especially the forces associated with towing (though i wouldn't tie off to just one cleat in a towing situation).
i'll go with the 4 bolt version, certainly with a beefy backing plate. i doubt i can get them mounted on the rail, but i'll look into that this weekend.
thanks as always!
When (if) you're being towed you should secure the tow line around the mast and just use the cleats to lead the bridle - much stronger than tying the towline to the cleats.
1 - 2 of 9 Posts
