During a sail last Sunday in the Chesapeake near Deltaville, while broad reaching in 12 knots apparent with our new (first time up the mast) A1.5 spinnaker, we lost the rudder. The boat did an immediate 180 degree turn to windward, the spinnaker went through the fore triangle and out to leeward, shredding it. When we couldn't get underway again, continually luffing up, we realized that the rudder was gone. We anchored, put on the PFDs, checked for water ingress (none), and called TowBoatUS (first time in 33 years). So now I need a new rudder for our 1984 Sabre 38 Mk I. Sabre hasn't built sailboats since about 2012, so they're out. I've talked with Foss Rudders in FL and they have a Sabre 36 mould that will work. They do the traditional foam filled mould around an armature. I'm also taking with Ruddercraft based in Boise ID. They will make a more modern custom foil for essentially the same price. Does anyone have experience with either fabricator, especially for a larger boat?
The rudder sheared at the waterline. The rudder post was 2 ⅞" but 38 years of corrosion left it with less than ⅛" wall thickness (down from ¼"). Stunning.
