Hi folks,
I always start a project then halfway thru decide I should have taken pictures to document the process. I remembered early this time so I will post this as I go along. Not a very exciting project but it's something we all have to do at some point and this may encourage others to tackle the same job.
I just picked up my new-to-me boat this fall and I pulled these off as soon as I had her on the cradle for the winter. They came off without any issues, about a 15 minute job start to finish. I drilled a small hole in the center of the plugs and then screwed a 2" screw down until it hit the screw head below the plug. A few more gentle turns and this will force the plug up and out of the hole. It may leave a few bits and pieces behind but I used a smaill screwdriver to encourage them to let go. No pics, just use your imagination. While removing one plug the rail chipped and a large piece of the teak came off. I will epoxy this into place once the varnish has been removed.
Here is a pic of a both rails, I had already started stripping one. You can see the difference between the bare wood and the weathered finish. I used a small orbital sander 80 grit paper and that ate thru the varnish quickly stripping the entire 3 loop rail took about 10 minutes. I then went over the entire rail by hand with 120 grit.
