1 - 1 of 15 Posts
Current distance from holding tank to head is 5 feet. Once relocated it will be approx 14 feet away. Any issues with the additional hose lengths?
Thanks for the feedback.
I wonder if you could install a vacuum pump (S series vacuum pump - Dometic Corp) in the line to the holding tank and still use the same toilet? You might have to disable the manual pump. Minimal water is required to flush. I am familiar with vacu-flush systems having rebuilt a a Dometic Sealand pump recently.
Just a thought, if not a solution.
-CH
1 - 1 of 15 Posts
