I'm removing the teak companionway trim, handrails, etc. to acid wash and recondition. I've never removed a good teak plug and replaced with a new teak plug before. I've read the best way to remove them is to drill a pilot hole in the center of the plug and drive a small screw in the plug that will extract the plug when it bottoms out on the existing screw head. Is this the best way? Any other tricks?
I have new 3/8" plugs for when I'm putting everything back together. I assume they are held in with more than friction fit. Waterproof glue sounds too permanent. What is the correct procedure and what sealant if any is used to hold the new screw plug?
