I would like to hear from anyone who has used the snap-on lifeline covers, offered by West Marine. I’m thinking of using them to cover my cracked and worn vinyl-covered lifelines, and I wonder how they hold up, over time.
Actually Dyneema lifeline material is less expensive per foot than stainless steel lifeline material with the same strength rating, Dynema single-braid is scarily easy to splice. New Years weekend I replaced all of my spinnaker pole rigging (9 splices) while watching a 90 minute movie. Piece of cake. The hardware is around the same price as wire terminals, but dyneema required fewer fittings., So you should point that out in your article. I personally would like to use heat shrink where the lines pass through stanchions but I am not convinced about applying heat on dyneema.Thanks both. Actually, I’m writing an article for a leading magazine, about the alternatives of replacing lifelines. Mine are cracked and chafed, but the wire is not damaged, so it’s a good place to experiment. I’ve worked on boats with bare wire, vinyl-covered wire and even rope, but never used the Davis Instruments snap on covers.
If cost was no object I would use 3/16” Dyneema, which is nice to grab and stronger than 3/16” wire, but it’s very costly and has to be eye spliced, which is a potential weak point.
The reason I like the snap-on cover is because it can be snapped-off as well, to inspect the wire as necessary, be it new or old. It also offers a thicker smooth material on which to hold.
Bare wire is horrible to grab with bare hands, but when my wires eventually needs replacing, it could be done with bare wire and the covers put back on. Also, if an individual cover gets chaffed it can easily be replaced.
By the way, I don’t work for David Instruments or West Marine.
As usual, it’s a boat compromise.
I'm genuinely curious how you were able to inspect the wire beneath the vinyl coating. Crevice corrosion is a notable weakness with covered stainless steel. To be "stainless" it needs exposure to the air.Mine are cracked and chafed, but the wire is not damaged,
Many say this, but I've never really understood it. For starters, the line shouldn't be grabbed much. I still don't find it much different either way. The theory that the twisted strands might capture hairs on one's leg or arms makes intuitive sense. Although, that's never happened to me either. I replaced all my vinyl coated with bare SS.Bare wire is horrible to grab with bare hands
I was worried about my cracked lifelines. They were ugly and i was worried about their reliability. I peeled off the coating and carefully examined them. They were and are in good shape, and the stainless is easier on the eye.I would like to hear from anyone who has used the snap-on lifeline covers, offered by West Marine. I’m thinking of using them to cover my cracked and worn vinyl-covered lifelines, and I wonder how they hold up, over time.
Oh no, he didn't say it! Prepare for incoming!I would like to hear from anyone who has used the snap-on lifeline covers, offered by West Marine. I’m thinking of using them to cover my cracked and worn vinyl-covered lifelines, and I wonder how they hold up, over time.
Your mostly likely just fine, if you saw absolutely no rust. Most cracked coating I've seen actually shows telltale orange on the vinyl itself. Mine certainly has. However, it's inside the twisted wire strands that is most O2 depleted and likely to suffer crevice corrosion. Some will see that orange sneaking out, clean it off and see the exterior strands look good, when the problem is not visible.I peeled off the coating and carefully examined them.
Dyneema melts at 140°C which is not very hot. How hot is a heat gun? The question is, does heating dyneema even close to melting point compromise it's strength?I'll second the Dyneema rec. It's got a better feel than wire. Nothing is easier to splice and Dyneema the same size as wire should have strength to spare anyway. And you don't have to go through the whole measure-and-have-someone-swage-it business, let alone the finding out after the fact that the length is wrong. I used 1/4" and the fittings that are made for splicing - no real difficulties. Colligo has some videos on line that were pretty helpful. Seeand
I am curious as to Jeff's point about heat shrink to protect the Dyneema where it goes through stanchions - would that much heat be an issue? Chafe protection would be nice for peace of mind.
Barb wire is worse!Bare wire is horrible to grab? They are meant for emergency... deal with it.
When I replaced my lifelines with un coated wire I got larger diameter wire for the new lines, so it was probably the same diameter as the old coated ones. That was probably 10 years ago,. I don't own the boat any more but it is still in the club, and last I looked they still look perfect.No doubt different folks have different results in different climes, but ours are 12 years old, out all year in Texas. No cracks, no stains or any other signs of wear or deterioration. I know it’s coming of course, and when it does I’ll replace. I prefer covered because the diameter is a little greater than uncovered, thus more comfortable.
Interesting point. Most heat shrinks are 90-100C. If you could control the temperature of the gun (maybe a hair dryer instead) it sounds doable.Dyneema melts at 140°C which is not very hot. How hot is a heat gun? The question is, does heating dyneema even close to melting point compromise it's strength?...
