I found a used wheel pedestal assembly on Craigslist. I had to remove it from an old Islander MKII 30. I plan to install it on my 1967 C&C 31 Corvette. It is not going to be an easy retrofit. My rudder shaft is only 1-3/16" diameter. The donor boat had a 2" rudder shaft. The wheel that was mounted to the donor boat looks to be too large to fit under my cockpit so I think I will have to trim it. It is an Edson pedestal and wheel.
Attached are some pictures of what I'm up against.
Comments? Suggestions?
