1 - 15 of 15 Posts
We've got a 1968 Soverel 33 with several generations of kludged-together antiquated wiring and it's a general confusing mess (Lucas electrics FTL); I'm planning to totally redesign and rewire the thing so that it's suitable for fulltime liveaboards (two of us) and eventual cruising.
I'm no expert electrician, but I've rewired cars and planes, and I was an ET in the service. I have the basic skillset but no specific knowledge that is unique to boats. I'm not afraid to get in there and try stuff to get the thing to work.
At the moment it has a 10A charger and no inverter at all; we only have 120VAC while hooked to shore power; it's hardwired to the two AC outlets. No shore power, no AC.
What I want to do is upgrade the charger and install two inverters and a third outlet. The AC power load will mostly be light--two laptops and a printer, a small space heater, and a small fridge; but with occasional large loads from a microwave. The boat has a small DC fridge which we're keeping--ain't broke, so not gonna mess with it--and the DC lighting system, which I'm going to rewire for neatness and switch over to LED light ASAP. We're going to add a second fridge that can store more than a sixpack.
My specific plan is to go with a 30-amp switchable 2-stage/3-stage charger; a single 750W MSW inverter (bought dirt cheap at a pawn shop, not my first choice, but too good a deal to pass up) to power the one V-berth outlet; and a 2.0kW PSW inverter to power the saloon and galley outlets which will carry more sensitive electronic loads.
The 750W MSW inverter will carry an occasional load of ~600W (small space heater, plus a digital clock, plus a small hair dryer (the heater will be turned off while the dryer is on)).
The 2.0kW PSW inverter will carry a steady load of ~250W (two laptops and a printer) and an additional ~350W (second fridge running on AC) plus an occasional load of ~1500W (microwave). We'll power down the printer while microwaving.
The DC system will remain, powering the antique-but-functional minifridge, the interior lighting and fans, depthfinders, radio, cockpit stereo, and all exterior lighting. Again, I'm just going to rewire the Edison wiring and upgrade to LEDs.
First question, and by far the most important: Does any of this sound at all stupid; i.e. am I missing anything obvious?
Second question: Is it preferable to mount the inverters in the cabin, or in the engine space? Are there any regs that specify placement?
Third question: I know this will also require breaker panels, and those I am not as familiar with (not common in cars or small aircraft) but it should not be a major technical challenge; will I need two separate ones for AC and DC systems? Can I go with a "universal" panel that does it all?
Fourth question: Down the road we're planning to add solar panels and a wind jenny; does anything I'm planning now preclude these, or are there things I can set in place now to prepare for these additions later on?
Last question: Anyone in Charleston want to get in on this? I'll buy beer and pizza.
Edit: At the moment we have three batteries and I intend to add more.
Cheers!
Mike
Marine Grade Wiring
Use primary wire to connect your batteries to positive and negative terminal plates. This should be around 6awg.
Marine grade wire is made of many thin strands, and each strand is coated in tin. This makes it flexible and corrosion resistant. I am not sure this is necessary (Cu is relatively non-reactive).
Marine grade heat shrink tubing has adhesive on the inside, and seals all terminals. Non marine grade would probably work... I mean, it is heat shrink tubing, I don't see why you would need adhesive.
Marine grade crimp-terminals are also tinned. Not a good place to skimp.
Do not use solder, it corrodes more easily than crimped terminals.
Do not use acorn nuts, not flexible, and poor conductivity can lead to fires.
Do not try to splice the wire by twisting it together, bad idea.
Battery switches are good.
Necessarily, this is all expensive.
Or just stuff it all and don't use the electric.
My general comment would be do everything you can DC TO DC the inverters really suck up battery life
For example i cant see running a small electric heater off and inverter as something that would work at all without enough batterys to sink the boat :D
I have to agree with Tommays. Running a heater ac fridge microwave etc is not possible unless you have the sort of battery bank that that is too big to fit on a small yacht. (OK maybe microwave just)
The inverter may be large enough, but the battery bank needs to be able to supply the amps and the amp hours to the devices.
You seem to be on the right track.
I do not think you want to use a heater off an inverter.
You might consider using the small inverter for computer stuff and the other 2kw for house electrics. The inverters should be below deck. Frankly, I think you would be better off with a single inverter but that's just a preference for simplicity.
You should have AC and DC breakers and voltmeters. Panels come in many configs and boy, are they expensive.
I looked at the interior plan on the class website and am curious where the new fridge would go.
There are “no free lunches’ in electricity. You need to re-think your plan and perhaps purchase some more efficient appliances. You got a lot of “house” loads. 250W equates to 21 amps @ 12v. Assume that the refrigerator cycles half time. 350W / 2 / 12v = 15A. Assuming 10% inverter efficiency factor, you burning through your batteries at a rate of 40 amps without turning on a single lamp. Assuming further that you are installing a pair of 4Ds as a house bank and you will discharge down to 50% before recharge and an 80% recharge efficiency factor, you will have something like 130 AH. Usable storage capacity. Your drain will only give you a little over three hours before a charge is needed. Running a high output alternator (assume 50 Amp continuous), it will take you 2 and half hours to recharge. Of course, everything would have to be turned off during the recharge. You will have to make sure you have proper cooling on the alternator (You may have to run the engine blower during the recharge.) The large alternator will also rob several horse power from your engine. In effect, you will wind up running your engine at more than a fast idle while you are using your appliances. Your little shore charger will have no ability to keep up with your loads. Better to wire a dedicated 120V circuit for these house loads.
Discussion Starter · #8 ·
Tager: Good to know about the soldering; I was planning to do a lot of that.
Ajari: I have Calder's book, second edition, not sure if that's the most recent. Sought it out at the local used bookstore and got lucky.
Tommays: Okay, we're reconsidering and looking into propane heat and cooking. Reduce the power load.
Noelex77: Clearly I need to know more about amp-hours available from different battery types. A weak point in my knowledge thus far.
39512: Well, I got one inverter for a steal, but it's not enough. And you found online plans for a '68 Soverel 33? I've had no luck whatsoever; all I found was the '77+ racing boats. But the new fridge will go where the ancient alcohol stove used to be.
GeorgeB: Like I said, I clearly don't know enough yet about "big battery" endurance. But already I can see I need to lose the luxuries--microwave, heater--and look at chemical alternatives like propane for cooking and "comfort heat."
I Also have to rewire my boat so I read with interest about your plans. Fortunately I just had my boat surveryed, it's a 1972 Hughes, 29 foot sailboat. The surveyor was really helpful. I have Calder's book referred to above, it's quite expensive (50 dollars). I find it good on the mechanical stuff but not so lucid on the electrical side. But if you have ET experience from the military it's probably ok for you. Check it out of the library though. Or find someone who will lend you a copy. The AC wiring in my boat, wired (I use the term loosely) consists of household extension cords wire nutted together (no kidding). So I have to rip out all the old stuff. Regs now require the AC current to have a shut off switch (ie. it needs a box). My boat is currently on land in Maryland and I'd like to find someone with experience that could walk me through the wiring so I can learn the nuts and bolts of it. In the meantime I'm rereading Calder's book. I grew up on a farm so I have basic mechanical skills but marine electrics is really different, particularly the grounding arrangements. But I'm still optimistic I'll sort it out. I'm going to try not to use the rule that my old physics teacher told us during the unit on electricity: "Wire for the least amount of smoke!" Smoke is definitely not what I want to see when I'm off shore. Best of luck.
Discussion Starter · #10 ·
Roy1948: Well, I got twofold lucky on the book; found it for $20 at McKay's Used Books, where I also had hundreds of dollars in credit from recently trading in the brazillions of books, movies, and CDs that won't fit on the boat.
Yeah, the wiring on ours is much the same; stuff that would make a British Leyland employee wince. It's all going away and being replaced with new, proper wiring and blocks.
And I still work in electronics repair and calibrations; smoke is bad. But it's also a good indicator of Murphy's location.
Just remembered because I made this error. I bought an automotive battery charger. The surveyor told me it was not allowed, you have to have a "marine" battery charger cause it has a built in spark suppressor. Also can't have the outlet for the charger in the battery compartment. My boat had it there and I also have to remove it.
I was given a tip by a Nova Scotia boat builder recently that the drop in the price of copper is working its way through the "system" (including marine wiring). So if you want to save a bit of money, watch the price closely for properly spec'd tinned two connector wire and buy a big reel of it, preferably for your largest typical load (14 gauge is good). You can sell what you don't use, because it's practically a commodity.
Also, to reduce runs, consider having your breaker box and batteries in a non-typical location, like on the saloon bulkhead and the batteries/charger/inverter under the settee. This makes access to mast wiring easy, shortening the runs, and makes the runs forward and aft about even (but of course you'll go LED lights, right, meaning you can use 20 gauge...).
Yes, you run a big wire to the starter and smaller wires from the alternator to the batteries, but this means you don't have to bugger about in a perhaps cramped nav station or under a quarter berth. Also, it gets a lot of weight in the middle of the boat, rather than back by the engine.
Just a thought. OK, several thoughts.
I am nearing the end of my boat rewiring project. I tore into a 1974 Pearson 30. Half was the original wiring and the other half was a hodge-podge of AC and DC from the two PO's. I am very fortunate to have found a great marine electric shop down the road from me in Annapolis. The prices for supplies are really good, and the owner is always willing to help. I design and build manufacturing equipment for a living, so I too had experience with wiring. Here are the tips I learned the hard way or was lucky enough to have someone share with me.
1) Do not go cheap on wiring, connectors, or the distribution panel.
2) Always use marine grade tinned copper wire. Pure copper will corrode, trust me
3) If you need to splice a wire, use adhesive lined shrink tube. This will mimmick the insulation and protect against corrosion, and water intrusion.
4) Do not use any wires smaller than 18 AWG. ABYC found that anything smaller can fail due to vibrations. I found 14 AWG to work for 90% of all my wiring needs
5) If you can, place a small terminal strip near your fixtures (lights, fans, etce.) so you can easily swap them out later
6) Check out the Blue Sea DC Circut wizard to help you with wire sizing. There is a link on thier main web page.
7) Draw a schematic before you start wiring. This will help you remember everything as well as be a great reference for troubleshooting later.
8) Buy a decent set of wire strippers and crimpers. Your hands will appreciate it.
9) Do your best to not solder. Soldering reduces the flexibility of the wire and can cause the joint to fail from vibration over time.
10) The most important of all... KISS. Do not over complicate your systems (for instance, keep it at one inverter)
There are many more, but these are the big ones.
________
The View
Mast Rewiring Advice - Pearson 28-1 (1982)
During the long off season here in Chicago I managed to get a few projects
completed and a few more projects started. One of my projects involved mast rewiring. As of this last weekend, I have replaced all of the wires in the mast - including the radio coax cable. I will now reconnect all when the mast is stepped. For the wiring I used insulated Ancor cable(14 gauge - similar to romex) and RG8X for the radio. I had a great deal of difficulty getting the electrical wires out and ended up using brute force to pull them out once the fixtures were removed. My initial thought was that they were tangled, but now I'm wondering if they were supported somehow internally as I now need to consider how I will support the wires. Although I have not faced the wire support issue yet, I expect to address soon with perhaps a knot (between the fixture and the mast)and /or hose clamp or even
a U clamp to the back of the fixture as needed. Part of my purpose for this
report is to ask if anyone knows of a slick way to support the electrical wires in the mast. The support is needed of course to prevent the connections from pulling apart. My radio cable is fine but the electical wires I haven't addressed yet. I had been thinking that perhaps the mast cap had a role but I have not been able to remove the cap.
I also intend to force pipe wrap insulation up the mast around the wires to
eliminate banging and wire wear.
Ideas? Lessons learned?
Thanks,
Bob
1 - 15 of 15 Posts
