1 - 20 of 21 Posts
The Rules of the Nautical Road, a Primer
I've noticed a general lack of knowledge of the Rules here and on other forums and on the water. While this is almost universally true for the casual recreational boater, it's also an altogether too common state for a large number people who consider themselves, and are, otherwise pretty serious seamen. Hopefully, my little primer can help rectify that for those who read it or at least make people consider learning a bit more about the Rules.
These are some of my thoughts and interpretations of the Rules. These are not the actual Rules. Those can be found here.
Why the Rules Matter
Some who are reading this have been been boating for years and you've never had a serious mishap with another vessel despite having a (way) less than perfect understanding of the Rules. You're probably saying to yourself, "It can't be that important to really know the Rules or I would have had a problem by now". Maybe you're lucky. Maybe you only boat in daylight hours and when the weather is fine. Maybe you figure that all you need to do to stay out of trouble with other vessels is to apply a little common sense and courteousness. Maybe you're right. Maybe not.
Deadly collisions are rare. So are environmentally disastrous ones. But rare and never ain't the same thing and if something catastrophic happens do you really want your lack of preparation to be the cause? Especially when it's really not very difficult to be prepared?
Next to understanding your (properly equipped) vessel and how to operate her really well, nothing is more important to your safety on the water than understanding the Rules.
For Starters
First, read the Rules (and keep a copy onboard your vessel). Don't just flip through them occasionally. Don't just look up a light configuration when the need arises. Don't just look up the crossing situation Rule to see if you or someone else did the right thing in this instance or that. Don't just rely on things you read here or on other internet forums (including this post) or on advice you get from your neighbor down the dock. Don't just take a Rules course from the CG Auxiliary or Power Squadron. Do all of those things, just don't do them first. First, read the Rules. Read them from start to finish. The Rules are an interdependent system that only makes sense when taken as a whole; you have to read the Rules first.
Second, study the Rules. Understand them. Memorize them when possible. Get a copy of the latest addition of Farwell's Rules of the Nautical Road and read it. If you're a visual learner (and even if you're not), make little paper boats and put them in the positions the Rules describe for the various situations (head-on, crossing, overtaking, etc.) and step through scenarios described in the Rules and scenarios you've seen. Draw the arcs of visibility of the lights on your paper boats so you can visualize what you'll see in those situations at night. Make light configuration flash cards (print this and cut out the pictures) and use them so that you'll know instantly what you're seeing in the real world. You usually won't have time to consult a book (or be able to see it) when you most need to know what those lights mean.
Third, understand that terminology is important; terribly important. Learn it and use it. Always. Use give-way and stand-on, not burdened and privileged. Use masthead light, not steaming light. That's a head-on situation you're in, not a meeting situation. Those red and green lights are sidelights, not running lights. It might seem pedantic, but the only way to have a reasonable chance at a common understating of the Rules is to start with a common lexicon.
Fourth, follow the Rules. On these forums I often read about "being courteous" or "just using common sense" when it comes to what to do in a given situation. That's a recipe for disaster. A big part of what makes the Rules work is that if everyone's following them, you can know what to expect.
I make one exception to this. In situations where I can establish communications with the other vessel before the situation gets ugly, I may, as the stand-on vessel, choose to maneuver after letting the other vessel know my intentions and getting her agreement (this is not in accordance with the international rules but it's generally accepted practice and passes the smell test).
Fifth, (almost) never turn to port to avoid collision. If you're thinking about turning to port, you're almost always thinking wrong. This is especially true if you think you're being courteous or using common sense.
The Navigation Rules and Regulations
Part A - General
Rule 3 - General Definitions: Definitions are critical. Memorize these.
Understand that there's no such thing as a "vessel constrained by her draft" in the inland Rules because almost every vessel is constrained by her draft in inland waters (at least some of the time).
Understand that almost no one here will ever be onboard a "vessel restricted in her ability to maneuver". That designation is for vessels that can't maneuver due to the nature of their work (buoy tenders, dredges, vessels launching and landing aircraft, etc) and you aren't working. Heaving-to doesn't qualify.
Know where the international/inland demarcation line is for your homeport. Know the compass bearing to a prominent object or a natural range between two objects for where you typically cross the line. If you're visiting an unfamiliar port, note the demarcation line on the chart before you start in.
Part B - Steering and Sailing Rules
Section/Subpart I - Conduct of Vessels in Any Condition of Visibility.
Rule 5 - Look-Out: This may be the most important Rule. Always obey this one and you'll rarely be surprised.
Rule 6 - Safe Speed: Be a prudent seaman when deciding how fast to travel. Understand that if you don't have radar, the weather is bad, it's dark out, etc. your safe speed may be very low or even zero. There's no shame in recognizing your limitations and responding appropriately to them and the conditions at hand. To the contrary, it's the mark of a seaman.
Rule 7 - Risk of Collision: This Rule is important because it tells you whether Rules 8, 9, and 12-18 even come into play.
Rule 8 - Action to Avoid Collision: Take note of paragraph (f) in this Rule as it is important when applying Rule 9.
Rule 9 - Narrow Channels: This Rule is interesting. While the first part of the Rule is clear, there's one aspect that most people, even professional mariners, typically don't understand real well. Namely, that this Rule supplements but does not override Rules 8 and 15.
Rule 9 instructs vessels of less than 20 meters in length and sailing vessels (and fishing vessels) not to impede the passage of a vessel which can safely navigate only within a narrow channel or fairway. But what if a sailing vessel or small power-driven vessel does impede the passage of a vessel constrained to the channel or fairway? The vessel that shouldn't have been impeded is not relieved of her responsibilities under Rules 8 and 15!
Section/Subpart II - Conduct of Vessels in Sight of One Another
Rule 11 - Application: These Rules only apply when you can see the other vessel. That means a couple of things:
  • Even though you may be able to use your radar to determine that you're in what would be a crossing situation (or head-on or overtaking or whatever) if you weren't in heavy fog (or squall or whatever), you're not in a crossing situation per the Rules. If you're in the fog or an obscuring squall, you're operating under Rule 19;
  • If you have a radar contact that's over the visible horizon, you're not bound by these Rules even if you're on what would eventually be the stand-on vessel. Thus, there's nothing keeping you from maneuvering to keep a situation from ever developing into something to which these Rules apply.
Rule 13 - Overtaking
: This Rule is pretty clear to most people. One thing to note is that this Rule overrides the hierarchy of vessels in Rule 18. The overtaking vessel is always the give-way vessel.
Rule 14 - Head-on Situation: Just come to starboard if you're in any doubt at all as to whether risk of collision exists. This is especially true if the paths of the two vessels will take them relatively close aboard in a starboard to starboard position. People are often tempted in that situation to come to port just a little to open up the passing. That's the first (mis)step in what's known as the Dance of Death. In this dance your initial misstep is followed closely by the other vessel seeing the situation for what it is (a head-on situation) and complying with the Rules by turning to starboard. This can obviously make your poor decision worse. When you finally figure out that the other vessel has turned to starboard, you decide it's time to do the right thing and turn to starboard yourself. At about that time, the other vessel figures out that you came to port, are clearly an unpredictable menace, and decides the only thing to do is to turn to port. The dance can go on like this until it's too late to avoid a collision. Think this doesn't happen? Think again. The collision between the Andrea Doria and the Stockholm is probably the most famous example of the Dance of Death, but it's hardly the only one.
Rule 15 - Crossing Situation
: If there's a good reason to turn to port when you're on the give-way vessel in a crossing situation I haven't seen it yet. Turn to starboard or slow down (you might be able to increase speed if you're onboard a very fast vessel that just happens to be going slow).
The Dance of Death is also common in situations in which it isn't obvious whether you're head-on or crossing. In that case it usually begins with the stand-on vessel (for a crossing situation) seeing it as a head-on situation and thinking a small turn to port will keep it from ever getting close. The other vessel, seeing a crossing situation, does the right thing and turns to starboard. Thus begins the Dance.
Rule 18 - Responsibilities Between Vessels
: The hierarchy of vessels. Note that this hierarchy is superseded by Rules 9, 10, and 13.
Part C - Lights and Shapes
You really just have to memorize the definitions of the various lights and what types of vessels are required to show what lights and when.
There is a convenient way to help you remember which vessels have to display masthead lights and sidelights and when.
  • The absence of masthead lights is an indication of unpredictability. Think about which vessels don't show masthead lights: Fishing vessels; vessels not under command; vessels being towed; sailing vessels; and pilot vessels. What do these have in common? They can all be expected to behave unpredictably. In the case of sailing vessels, this is because they may turn while tacking or wearing without the reason for the turn being apparent to other mariners (e.g. while beating up).
  • Sidelights show aspect. When aspect isn't important, sidelights aren't required. This generally means vessels, other than power-driven and sailing vessels, that are not making way through the water, are not required to show sidelights.
Part D - Sound and Light Signals
Here again, you just have to memorize this stuff.
Conclusion
This isn't, by any means, a complete treatment of the Rules. Just some thoughts and musing I've collected over time. Depending on how this is received, I may post some other things I've written on the Rules over the past 27 years on and around the water.
Seeing that I teach the RoR to students going for their 100/200 licenses I really don't think that you mean me. :rolleyes:
And what you have presented in your post is a very condense and abridge version of the Rules. And as such does give a dangerous presentation of the Rules.
Get the actual Rules from either by downloading from the USCG or by buying the Rule book and study itself.
By the way when you are applying for a commerical license you have to score a minimum of 90% on the test.
I agree that many of the people out on the water do not either know the Rules or elected to not abide by them because they think they are special for some stupid reason.
Discussion Starter · #3 ·
As I stated in my original post, I presented my thoughts on the Rules and not the actual Rules. That post is not an abridged version of the Rules.
I edited the original post to put in bold type the statement that these aren't the actual Rules and also put the link to the actual Rules in bold; it's even harder to miss now.
Even though you and I may have had a heated discussion on this. There are many people who really don't understand the rules or even believe that there are not any laws on the water.
The seas are not patroled like city streets and that adds to the illustion of lawessness on the waters. So the Amateurs out there don't see any reason to study the rules and learn how to apply them to their vessel. I guess their own safety and of others don't matter to them.
I would like to put the blame on the PWC, Those are only a small part of the problem... And many people like to party hard and being on a boat load down like a Rum Runner really helps them party but does not help in safe boating. So there are many reasons why people ignore the Rules... Just as most of us have sped down the highways & city streets and along with other traffic violations.
When I am teaching the Rule I do liken them to street rules and use that as a reminder that the Rules are there for our safety, are needed and it is Mandatory to obey them at all times. And trying to get those rule ingrained into their heads can be nigh on to impossible at times... But I have a Pass rate of about 98%, so must be doing something right. But all they have learned may drain out of their heads after they walk out the doors.
Sport Fishermen?? Had a couple cross my bow from port to stbd while they were trolling. Claiming that they had the right of way... I was transiting a marked channel and couldn't move out of it to avoid them. Crash stop was all I could do...
And had a sail boat with the sails down claimming right of way because they were a sail boat...
To sum it up... There are a lot idiots er! people (sorry) that do need to take classes in the Rules of the Road.
Kurt - that lack of knowledge you noticed around here is probably me. I don't know squat - and put that on display virtually every day. Thanks for the primer, dude.
I do have to say, though, that I'm guilty of this:
"Fourth, follow the Rules. On these forums I often read about "being courteous" or "just using common sense" when it comes to what to do in a given situation. That's a recipe for disaster. A big part of what makes the Rules work is that if everyone's following them, you can know what to expect. "
I don't trust anyone on lakes. I avoid them all. Basically, because I assume they know even less than I do. And especially when I see that their beer bong has no running lights...oops, side lights. Always a give-away.
Kurt, nice job with your summary. While I am generally fairly familiar with the rules, I found your post to be helpful and instructive.:)
Along the lines of what Smackdaddy commented above, I will quibble with you on this point:
One essential fact not to be overlooked is that there are more than a fair number of boaters on the water that do not know ANY of the rules. No experienced boater should be operating under the assumption that everyone is following or will follow the rules. In my mind, that is the real recipe for disaster.
Sometimes it is difficult for professional mariners to distinguish between what they know is RIGHT in an absolute legal sense, and what is RIGHT in the real world that small boat operators encounter while engaged in their recreational pursuits. That's your training and laudable professionalism coming through. And don't get me wrong, I share your view that the rules should be adhered to as closely as possible. But I bristle at the assumption that everyone on the water will be following those rules, or even that we should expect everyone to know them. It's simply not realistic.
In near coastal areas where the majority of recreational boating takes place, at any given time there will be a certain number of absolute novices operating motor and sail boats. All summer long, up and down the coast, kids are learning to sail in dinghies and on windsurfers. If we require those kids to master the Rules prior to casting off to learn to sail, our sport will be DEAD within a generation (much the same result as telling folks they're not allowed to ride a bicycle unless they already know how to.)
And we are most likely to encounter those inexperienced boaters in narrow channels and congested approaches, when the "Rules" would seemingly most dictate the conduct of vessels. And that is why the wiggle room provided by the "common sense" exception must be acknowledged. If the CG were to conduct a census of recreational boating activities under these circumstances, they might not be surprised to learn that the common sense exception prevented far more accidents than strict adherence to the "Rules.";)
I think part of the problem with some recreational boaters is they know there are rules but they think they only apply to commercial vessels. And as Bosun said many are just unaware.
I guy working on a job I was on crashed his go fast boat into the shoals at the entrance to the Niagara River about 10 years ago. He was complaining that somebody should have put up a warning sign or something, appearently the water rippling over the rocks wasn't clue enough. I told him the rocks and depths are shown clearly on the chart and showed him on the one I had in my truck. His answer..."you mean they make maps of the water?"
Discussion Starter · #11 ·
That's a very fair point. My statement was too idealistic; there will always be a sizeable contingent of very uninformed people on the water.
What I should have said is that the best choice is to follow the rules rather than to act outside them in an attempt to be courteous. Of course there's nothing wrong with being courteous, it just needs to be done per the rules whenever possible. That's usually just a matter of communicating your intentions to the other vessel before you maneuver.
Kurt,
Our laudable professionalism and training are based in the real world... We don't sit in some academy, college or university and expond on the rules with no real world experiences like many of those academic professors do.
You will find that many Professional Mariners have had many close calls and understand that discretion & purdence are very important in applying the rules. But if your read the casuality section of the magazine "Professional Mariner" you will find that some professionals are not as professional as they should be. So just because some people have a license, as I've stated before, when they go out the door with certificate in hand, all that they have learned seems to drain out of their heads...Another form of Brain Drain.:eek: :rolleyes:
A lot of the collisions could have been prevented by Communications... AIS is a good thing.
Communicate, Communicate and Communicate some more... And STAY AWAKE!!
So Be Careful Out There. The Life You Save, May Be Your Own.
I have a buddy who is a very busy surveyor in my area. He recommends me for delivery jobs and we are good friends. One of the stories he tells is a Classic.
He got called by marine insurance co. to go give a damage estimate for a power boat that had sunk in it's slip. The boat had been re-floated and was on the hard. My buddy called the boat owner and told him he would be at the boat at a time and date and as the boat owner he could/should be there also.
As my buddy says when he first walked up to the boat there was a chunk missing out of the bow. When Bill got on the boat there were empty beer cans and blood and teeth in the cockpit. He went though the boat and it was a total loss. The boat owner shows up a hour later, with missing teeth and black eyes.
Bill said, I just had to ask the guy how this happened. The boat owner went on to explain that he was lucky to be alive. That he hit the buoy in front of the marina and was lucky the boat did not sink until he got back in to the slip.
The boat owner went on to explain that he was going to sue the Coast Guard. Bill asked the boat owner what are going to sue the CG for? The boat owner said "the buoy was defective." Bill asks how can a buoy be defective?
The boat owner says, " the buoy"s light was only staying on intermittently."
Bill said, I just to ask the guy how this happened. The boat owner went on to explain that he was lucky to be alive. That he hit the buoy in front of the marina and was lucky it did not sink until he got back in to the slip.
Good lord, and we wonder why our boat insurance preiums are so high. If it's not alcohol...it's stupidity. Geez! :confused: :mad:
Thanks Kurt for the much needed post. For me it was particularly good to see because For the past week I have been reading my copy of the rules of the road from cover to cover just as you recommend. This is somthing I do at least once or twice a year and it was good to see someone else recognize the value of it when I see too many boaters who either don't care, or don't know enough to care. Rick
While there may be arguments for licensure, just remember a licenses if required to operate a car. Just having a license does not stop stupidity. Common sense does not have a 100% corelation with intelligence. Nice job Kurt, I am reminded of our opening comments get a copy of the rules and read them. You post was a good reminder.
1 - 20 of 21 Posts
