I have a couple of questions all centered around my anchor chain (5/16 G4). We have 170' of chain plus 100' or so of rope for our rode. We typically only use about 70' of chain as we are not anchoring in too deep waters in the Chesapeake. This 70' has rusted, hopefully not to the point where the links are structurally unsound. We have the rode off the boat and hit the rusted up area with a power washer to flake off the loose stuff. When it is dry, I plan to evaluate the links to see what has flaked off, if anything.
So I am pondering my options.
I could replace the entire chain rode at $500+ which is not really in the boat budget; My good friend suggested that we get the loose rust off and then coat the chain with epoxy which would seal it and hopefully give us another 4 - 5 years: I would then turn it around so that the expoxied chain is at the other end. I could cut the bad chain off and replace it with new chain but how would I connect the 2 lengths of chain so it would work with my Maxwell vertical windlass? I could eliminate the bad section of chain altogether as I have plenty of rode left but when we leave the Chesapeake for more offshore cruising we may need more chain and we are back to dilemma of how to connect 2 chain rodes.
What do you think would be best? Any other options I haven't thought of?
Tod
Tod
