141 - 160 of 301 Posts
Out of mild curiosity, what is the amp draw on an induction stove-top? I am assuming that this set up would mean an electric oven too? I like my propane (but then again, I cook with gas at home). Never once have I had a flare-up like when I had an alcohol stove and singed the cabin curtains. We used to have a paraffin trawler lantern in the cabin but got tired of the oily film and soot on the overhead if it wasn’t adjusted properly. But, I can see where propane or electric might not be practical for Jack’s boat and budget. Get what you can afford and take proper precautions and enjoy your boat.
George,
I'm not an electrician. I believe with a typical 110v, 15 amp circuit, the absolute maximum deliverable wattage would be around 1800w. I believe that's why most of the portable units on the market are 1500 watts. I hope I've stated that correctly. One would need a dedicated circuit for each 1500 watt unit.
Out of mild curiosity, what is the amp draw on an induction stove-top? I am assuming that this set up would mean an electric oven too? I like my propane (but then again, I cook with gas at home). Never once have I had a flare-up like when I had an alcohol stove and singed the cabin curtains. We used to have a paraffin trawler lantern in the cabin but got tired of the oily film and soot on the overhead if it wasn't adjusted properly. But, I can see where propane or electric might not be practical for Jack's boat and budget. Get what you can afford and take proper precautions and enjoy your boat.
George... it sounds like you're a little curious and you should be. My induction stove is super efficient... why?... one simple reason... it draws only the amount of electricity it needs in an instant to heat water or whatever... uses only the power it needs and nothing else... unlike an electric stove with resistance heating it must warm up... ever plug in a soldering iron waiting for it to heat up or an iron, etc.... that is the resistance element heating up and must be at full power to get to proper heat... that is wasting a lot of wattage right there... not so with the induction stove... it's electronic and turns on and off as needed to maintain the temperature.... your electric stove is on all the time at at set control timing.
That really is the difference... it uses very little wattage!
And to Tempest it ran on a 2000 watt pure sine wave inverter but I wanted power for other items so exchanged it with a 3000 watt pure sine wave inverter... works beautifully if may say so. My added plus is I'm not buying $12.00 a gallon of alcohol or the danger of an alcohol spill or fire!
Jack would need an alcohol stove or whatever he likes... my induction stove is not the cheapy units you see advertised on TV and is a chef/restaurant heavy duty quality unit and wired to the inverter with heavy 30 amp cabling... and inverter cables to the batteries are marine grade heavy duty cables. Not cheap for the faint of heart on a budget... the inverter alone was almost $800.
So, am I calculating this correctly? at 1,500 watts, my draw would be 125 amps? So a simple 15 minute meal would "cost" my electical system 31 Amp hours? This would certainly tax my two 4D house bank.
Math is wrong... it should be 1500/60 minutes or 25 watts per minute... not 1500 watts per minute... appliances are rated per hour usage... so for one hour of the induction stove use it will use 1500 watts... problem is it's not running 1 hour... but 5-10 minutes at the most... so 5*25 = 125 watts power used... 10 minutes is 250 watts, etc... pretty simple... there are numerous power/wattage calculators that will tell you based on how much power the appliance is using... your figure would mean a 1500 watt heater in the cabin is also using 121 amps too... how can that be George? Shore power is only 30 amps!
You must be asking how much amps is it using... 1500 watts/ 110 volts = 13.6 amps per hour... so based on that 5 minutes usage is: 1.136 amps... 10 minutes of usage is: 2.272 amps.
That is the total power being drawn from the battery +/-.
Clear now?
Guitarguy, when I do the math your way, I still come up with 31 Amp hours per 15 minute "meal". I am not so much concerned when I am tied up to the dock but for the times I am "off the grid". Like outbound, my biggest headache is those at sea days when my navigation system, radio and lights are a major consumer of my house bank. for example, my sensors "cost" me 48 AH per 24 hours, and the chartplotter another 60. My housebank only has a usable capacity of 150 - 160 AHs and my solar panel isn't the most efficient with the boat rolling and yawing.
I think your math is wrong guitar guy. The amperage on the DC side of the inverter is going to be a little higher.
Georgeb is correct.
Discussion starter · #148 ·
I guess the point becomes that there are a variety of safety hazards onboard. You could sink, catch fire, receive a blow to the head, inhale toxic gases or choke on a olive. I think the danger of propane is very low compared to the other dangers onboard. Propane has a distinctive indicating smell and with certain precautions can be handled safely. An accidental jibe because of a wind shift has more potential to injure myself or my guests. If the world scares you, stay home.
a person could use that argument against a person that thinks a motor is a necessary piece of safety equipment on a sailboat. do you happen to have a motor?
and, i'm willing to bet you have the usual boat load of technological gadgets on your boat. sailing without GPS and all the rest just wouldn't be safe, would it?
but, because i want to choose the safest fuel to use in my bloody stove that means i am too scared to sail so i better pack up and go home?
to quote don casey: "On a boat, LPG is also, by far, the most dangerous cooking fuel. "
check it out:
i built my own chopper. it has no front brakes. no rear shocks. a rake of 50 degrees. and a right hand suicide shifter. i love to ride at beak neck speed on twisty roads. i'm not exactly a timid guy. however, i'm not dumb enough to stick a hand grenade up my butt, with the pin pulled, and ride down the road hoping my sphincter can hold the lever in so it doesn't blow my a*# off.
give me a break.
Or does this have to do with your girlfriend again? Scared she is going to blow up the boat? Come to think of it, there are a lot of hard surfaces around too, better get out the foam padding.....
George... let's look at it again... 1500 watt appliance running 1 hour will be 1.5 kwatts per hour... a 1500 watt appliance running on 110 volts is using 13.6 amps per hour... ask any electrical engineer, electrician, etc.... the usage of watts drops as the appliance is reduced in time per minute.
Here is a simple calculator:
Calculate the Costs to Use Electricity - WebMath
add the 1500 watts and the number of mintues... see if you don't get the same answers I shown you... you may have to convert kwatt hours to minutes to get the actual watt/minute usage.
Does it make a little more sense now?
Discussion starter · #151 ·
I get that bud...sprry if it sounded like a snip
get whatever fuel you have best access too and enjoy the most...you have options up there so that is great for you
I just didnt see what the boat model had to do with anything but obviously if youre not ever going to travel with the boat at least overseas then yeah no issues with alcohol
having said that I posted before that even when I was in berkeley not every place had alcohol...and west marine was way expensive and it was more of a hassle than simple propane
for whatever thats worth
hope you find a cooking method that suits and pleases you
its very apparent that you have OPTIONS:)
i wouldn't say you sounded snippy. just like you were feeling a bit attacked :) annd it's no wonder. this thread has, like so many threads, gotten a bit hostile from time to time. i know we all have a passion for sailing but i'm not quite sure why that almost always has to turn into conflict and hoatility any time there is more than one opinion voiced.
everyone has an opinion and the purpose of threads like this is to hear as many of those opinions as possible to help in making an educaed decision. not sure why the multitude of opinions means hurt feelings or hurled insults( you know, because i'm obviously too chicken s%$# to sail because i want the safest fuel possible so it's not my boat i find burned up at the marina).
anyhow, you are right. i have learned i have a number of options to choose from....and that is good.:)
Watts do not have a time component, they are an instantaneous consumption. Watt/hours have a time component. None of your math makes any sense because of this mistake.
The pair of group 24 batteries in my house bank are rated to 160AH total, but I can only draw them down about halfway to get good service life. That is 80AH at 12 volts, which is 960 watt hours.
It is easy to compute power consumption for an ideal system. It takes 4180 joules to raise 1 liter of water 1 degree C. If the water in my boat's tanks is at 15C (60F) and I want to raise it to 100C (boiling) then I need 4180 * 85 joules, which is about 100 watt hours (98.69 to be exact). No system is 100% efficient, this is the best possible result that you can get.
1 liter isn't a lot of water. Making a basic pasta dinner with 4 liters of water and a half liter of sauce on the ideal induction heater would consume about 450 watt hours, or almost half of my house battery system. It would take my 30 watt solar panel 15 hours at noon-sun (or 3 Seattle summer days) to recover from that use assuming an ideal battery system. Again, nothing is ideal.
I don't see how using an electric stove on a sailboat makes any sense unless the boat is mostly used at dock and is tied into the power grid.
Discussion starter · #153 ·
Outbound... I'll take it you've never been around or exposed to induction stoves or ovens... let's just say I can place my hand directly on the stove surface while it is running about the only thing that will happen is smearing the black onyx surface with my hand oils... try that with a regular electric stove and I understand how your second shift crew would be burnt. Doesn't and will never happen on the surface of an induction stove... So in reality your rant doesn't apply here. As I mentioned my next boat will be entirely induction stove/oven and I see marine units are already hitting the market... but why wait? As mentioned I have my Honda 2000 but never ever ran it to make a meal using the induction stove. This is after all on a 25 foot boat... why the criticism if it should plainly work on a much larger boat with generators charging the batteries and hefty solar panels charging, and Torquedoes up the rear charging away?
that's one heck of a safety feature.
Jack, given your boat, budget, and aspirations, I'd say go with the alcohol stove. Why go through the expense and space to put in propane? All fuel is dangerous to one degree or another and as you can see by this discussion, the differences are getting down to hair splitting. Boatus says propane is safe as evidenced through the claims they payout. I have owned boats with alcohol for 13 years and propane for 15. I had one fire with alcohol and so far, none with the propane. My experience may not be everybody's. But I don't see it as the fuel for you. Nor do I see coal as your fuel (the cooking fuel of choice for over a hundred years before kero took over).
Guitarguy, my boat runs on 12 volt DC so I divide watts by 12V to get amps, not 110V as you would for shore power. Do I assume correctly that these stoves only work on 110VAC? Then I would also have to calculate the loss going through the inverter. Is there an induction oven too? What is the efficiency of that unit?
A professionally installed propane system will not leave your boat burned up at the marina.
Throw a couple of rusted out 1# bombs in the lazerette and you might have a different outcome.
A properly installed system has a shutoff at the propane locker that is vented to the outside (preferably from the bottom)
When the solenoid is shut off there is no gas to be had inside the cabin regardless of what has happened to the lines.
Propane explosion while boat us unattended at the marina, negligence is most likely the culprit.
Also, is this actually an explosion caused by propane, or a simple fire due to something like poor electrical?
Maybe the safest course of action is just not to cook onboard?
4.180 Joules for 1 gram of water, 4180 joules for 1 liter (1000 grams) of water. I'll go correct my post too.
Discussion starter · #158 · (Edited)
oh, yes. that's right. because i was thinking of fabricating a jib boom and going self tacking i was just destined to be a powerboater before long. funny. it's been 18 years, sailing, so far and i've never even used a motor on a boat, before.
i'd love to know why you are so easily offended with how i consider outfitting my own boat? what's it to you? i'm not telling you how you should set your boat up. you don't hear me implying that you are a non-sailing pansy if you use a motor to leave and return to a dock. i figure it's your business. but, obviously, anything i consider about my boat IS enough of your business for you to take offense and fling fairly blatant insults about my fitness to sail.
no. it has nothing to do with safety while i am on the boat. i figure i am competent enough to handle that. i am worried about getting that phone call from the marina. i already saw one black and burned out shell of a boat at the marina, this year. i don't want them to call and tell me that mine has met that fate.
again, i think it's foolish to totally ignore the fact that propane is the most dangerous cooking fuel on a boat. i think it's just a point of wisdom to explore the options. you know...not just be a sheep and do the same thing everyone else does because everyone else is doing it.
i have to wonder, are you threatened by people who consider different options than you or just easily butthurt if everyone doesn't automatically do things the way you do?
loads of boats have used, and do use, jib booms and self tacking jibs. that's a fairly traditional set up. lots of people use fuels other than propane. does it also bother you that there are people converting their 'perfectly good' bermuda sloops to junk rigs? do facts like these keep you awake at night? is that why keep popping up in my threads telling me i don't have gonads enough to sail?
i can't tell you how many times sailors in bigger boats have told me they thought i was crazy to be sailing my little dinghy out in wind as heavy as i often do....just think what they'd think if they knew that i don't know how to swim. but, you're right. i'm too timid to sail. i better sell all three of my sailboats.
Discussion starter · #160 ·
coal. boy that would take up some space on board and cause some real soot.:)
actually, if i was to decide to go propane i'd want an outside tank locker and i really don't see the room for that, on my boat. it would just take up too much space. i do think that pressurized alcohol will be my best bet, as you said.
