1 - 14 of 14 Posts
Discussion Starter #1
Given the history of the Golden Ray I remain highly skeptical.
Hull shaped like a sail.
Good idea?
Barquito
Maybe they could add floodable compartments that will sink the ship lower into the water for adverse wind.
Interesting - in the way that rotor-driven ships are interesting. They're going to beat to windward and work the angles for tacking downwind too? Imagine a 1000' LPG tanker suddenly tacking or jibing in front of you!
Trying to reduce wind resistance by going deeper in the water increases hydrodynamic drag. That's like the difference you feel in hanging your feet over the windward side, hiking, and dragging your feet in the water over the leeward side, to cool off. Which slows the boat more? It's surprising that they're not anticipating using LPG for the auxiliary engine's fuel - they're going to have plenty of it available.
Master Mariner
I think it is fascinating how the industry and artists fail to consider the actual underwater body of these ships in their initial adverts. The vessel below rolled over in a channel, in calm weather without sails or, as far as I've been able to determine, and reason. And this is the base for the design of a wind powered vessel? Cray cray.
137213
The car carrier that rolled over off of St.Simon's Island (near Brunswick, SC) apparently had a fire on board, and the pilot steered it into a sandbar alongside the channel. The top-heavy ship hit the sand and it flipped the boat over on its side. After trapped crew were removed, they've spent the months since slicing the ship into sections with a huge cutting chain, and removing them.
Master Mariner
I read the fire happened after she capsized, but....?
Master Mariner
When I see a ship with a sail, I immediately remember the tale about Assol
Googled Assol and came up with nothing. What are you trying to say?
Discussion Starter #11
“Assol”, say it fast and it kind of sounds like a slur!!!
Master Mariner
I saw that but didn't see the reference. Is he just a troll?
Master Mariner
1 - 14 of 14 Posts
