- Reaction score
- 19
Yes I am very interested in seeing pics of the mods you mentioned.OP, while we're on the topic of Albergs and seaworthiness, I'd like to mention some other areas you might consider. Chainplates and their gussets is an area to upgrade. The stock ones are anemic at best, and undersized (as you probably know already). I built up all the gussets with glass cloth and epoxy, made them very thick and better adhered to the hull, then made 2" wide by 1/4" thick bronze chainplates. I used big 1/2" bolts and nuts in them (bronze as well of course). They were rock solid and the deck would pull apart before they would. I can post pics if you're interested in seeing them.
Also worth noting is portlights. The A 30 has big windows and we had planned drop boards (never got to it before selling though). We took the original cast aluminum frames and wrapped them in glass cloth and epoxy, then used thicker than stock glass and through bolted everything. Sealed everything including portlights above the waterline with butyl. Never a single leak with that stuff. Also, as you can see in the pics, we added four round opening ports - one in front of the V, two just forward of the main cabins big ports, and one large one on the rear bulkhead. The ventilation they provided was very much needed, as the A 30 interior is a floating basement.
We took the seaworthiness thing (exterior wise) pretty far. We sealed up every through hull except for the scuppers, I made each compartment inside the hull an epoxied water tight bulkhead containment area in case of a holing, etc. I have pics of all this stuff if you're ever interested in seeing it for your own research.
The A 30 is a great boat, but honestly I don't know if I could recommend to anyone to go too far work wise on one. After we finished, I kind of wished I'd just bought a Bristol Channel Cutter and hit the road right away (sea I guess).
Much appreciated.
