61 - 67 of 67 Posts
Super Moderator
Discussion Starter #61
The dog and I are weathering a pretty good thunderstorm in it right now. Its holding up pretty well. Just had to put our bags on the windward side to keep the corners from folding in.
Super Moderator
Discussion Starter #63 (Edited)
Complicated socially distant visit with grandparents.
Not sure I could swing a backstay with a home made poly tarp sprit rig.
The sprit rig is surprisingly effective on the canoe. I went with almost a square shape to get the CE down as low as possible.
Didn't run a GPS today, so don't know what speed I hit, but the Grumman was throwing a substantial wake, so I am guessing over hull speed, in some pretty light winds too. Don't expect much performance to weather though.
Super Moderator
Discussion Starter #65
Yes, made the sail myself in about 2 hours using the good parts of an old winter cover and 2 sided carpet tape. Cost was maybe around $10. It works pretty well too.
There are quite a few online resources and books that cover polytarp sails, but Duckworks has a pretty good over view here. Making a Polytarp Sail
First time sail makers can get kits from a company called Polysail International with instructions and materials, price is a little over $100. I haven't used them myself, but I have heard good things.
S2 7.9 Bear Lake, UT
Thanks Arcb,
I have more sails and tarps than I know what to do with. My last boat purchase came with a larger sail inventory than I believe my last 4 boats combined had. I also have 3 different canoe/kayak sails.
I have been doing a lot of camping and creating custom tarps for boat covers and camping shelters would be awesome.
Super Moderator
Discussion Starter #67
Update. She is starting to look more like a boat and less like a collection of lumber and parts.
- I have increased sail area from 27 to 49 square feet and switched from polytarp to dacron.
-I have moved the mast step forward to the original Grumman factory position which allows for through bolted mast step and mast partner. I found during test sails, glued (5200) mast steps were unreliable.
-added the cheap inflatable amas on an 8 ft 1.25 inch aluminum aka, which gives me an estimated +160 pounds of righting moment.
-Also used the aka to.mount the pivoting lee board on. I did have the leeboard mounted on the partner, but that put my CLR too far forward and the boat wouldn't balance right.
61 - 67 of 67 Posts
