This coming summer I am planning to take the family (four plus labrador) up around the top of Scotland to Orkney (maybe Shetland) and around cape Wrath in Westerly Centaur if I can find one cheap enough)
I have been offered the loan of one of these - which has an inflatable keel - it is not a real keel just a bump in the floor - but I assume it should give it some more directional stability.
Key features | T32IE2 | Inflatables | Marine | Honda (UK)
Most of the time it will have the little Honda 2.3 on the back
but I hate the noise of the thing and there are some fabulous beaches and inlets to explore - perfect white sand, crystal clear (ice cold) water.
I have an old Optimist rig (used for the duck punt) and the space to stow it so I thought that I would try to get the thing sailing by lashing the optimist rig to the thwart
My plan is to fit a couple of plastic rowlocks on the transom either side of the engine and use a long wooden sweep out the stern for steering, create a mast step using a sheet of ply under the thwart and wedged in place using the tubes and use a second sheet as some sort of leeboard.
I am not expecting it to beat to windward but if I can get it to reach then I can sail in one direction and back the other. I am assuming I can get it to broad reach or run.
Has anyone on here tried such a thing - and do they have snaps or heart warming success stories.
I have seen the sailing kits
Sailboats To Go » Catalog » Inflatable Dinghy Sailing Rig
you can buy but I want this to be simple quick to assemble - and next to free
I am assuming that I will have just the one lee board and swap it over when I change tack.
Dylan
Dylan
