1 - 5 of 5 Posts
My buddy of mine in the boat club owns a mid 60's Sailmaster. Very Nautical looking boat with a wood mast and hanked on fore sail. His is swing keel and has had the outboard well fiberglassed in and has a Atomic 4 in is place. I have sailed many hours on his boat and the boat stands up to blow better than you would think, she points well and out sails her PRHF rating. Construction wise she is a solid boat. Bill Tripp knew what he was doing.
Super Moderator
Farr 11.6 (Farr 38)
I have always liked these boats. These were the quinessential 1960's era MORC racer/cruisers. They were nicely built in the Netherlands and featured very nice fiberglass and wood work. They sailed very well for that era across a wide range of conditions, but obviously the better designed newer designs will sail better at the lighter and heavier end of the wind range. The centerboard (not really a swing keel as it was comparatively light) allowed reasonably good performance upwind and still allowed shallow draft.
These boats came in a number of versions including a weekender with a spartan trunk type cabin and a 'cruising version' with the Tripp swoop type doghouse and trunk cabin. Accompdations were simple but workable. They came with either an inboard engine or an outboard well. Outboard wells were a pretty poor set-up and one that I am glad has faded out of modern boats. Sailmaster 26's well was not as bad as some but I would try to find one with an inboard engine, or which has been outfitted with an outboard bracket instead.
They originally came with wooden spars which would be close to shot by now. That said, some of the later ones had aluminum spars and many have already been updated with aluminum as well.
This has always been a boat that I looked at with a certain sense of nostalgia from my youth. I have sometimes thought that if I ever get too old to sail bigger, higher performance boats, the Sailmaster 26 (or boats like her) would make a great boat to sail out my final days on the Chesapeake Bay poking into the quiet corners that I missed sailing deeper draft modern boats.
Respectfully,
Discussion Starter · #4 ·
Thank you...
Gentleman, thanks very much for the replies, especially you Jeff as I've found your commentary on all boating aspects at sailnet awesome. This will be my first serious sailboat (minus the wooden Thistle I owned previously). The 1966 Sailmaster I'm interested in is the "cruising" version. Completely original down to the gelcoat (and with aluminum spars). Sincerely, Ian
Update
Hi, Ian. I'm looking at a Sailmaster that has become available in the Annapolis area. How has yours worked out six months later? Is it an inboard or outboard? Are you sailing yet? Any insight would be welcome.
John
1 - 5 of 5 Posts
