What caused this? Was it a following sea coming in through your exhaust? How did it get in the oil, and how would starting it once a day prevent this issue?
MedSailor
For 15 days we had big (15+ ft) swells hitting the stern every 15 seconds. Eventually it pushes enough water up the exhaust to fill the muffler. From there it moves up to the exhaust elbow and then into the cylinders with exhaust valves open. After a while I guess the water in the cylinder makes it's way to the oil sump where when mixed with the oil by boat rocking and rolling the oil looks like chocolate milk.
While it may only take one wave to fill the muffler, my guess is that it takes a bit longer. My theory is that by starting the engine every day we blow any excess water out of the muffler and thereby reduce the probability of water finding it's way into the engine.
The morning of our arrival in Sint Maarten in 2000 we tried to start the engine. Turned the key and nothing happened. We quickly checked the battery and found it OK.
We were lucky that we had one cylinder completely full and so the engine was "locked". Had we had only an inch or less in one cylinder the engine might have started to turn over. As water doesn't compress very easily
something would have to give....usually internal parts get bent/break. So, if this is gonna happen to you, pray the cylinder is completely full so the engine won't move at all.
I won't go into all the gory details of how you do the repair, but it's messy and you end up having to change the oil at least three times before all the water is gone. Once all the water was gone, the engine worked well for another dozen years. Only problem the water intrusion is that it corroded the effected cylinders just enough that it eventually caused was a drop in compression in the two cylinders where water got in. By 2006 pressures in these cylinders were down significantly but still above factory spec minimums. The problem was the differences in pressure between cylinders was out of spec.
The engine still worked well and was reliable, but it was wearing out faster than it would otherwise. The other problem the excess corrosion in these cylinders caused was over pressurization of the sump. As gaskets got older the excess pressure started small see pages of oil into the bilge. Oil diapers needed changing regularly and the lost oil needed replacing. A nuisance -- yes, but not a major issue unless you're about to go cruising for an extended period and you don't want to be nursing a 20 year old engine in foreign ports.
That's when you go out and spend a small fortune re powering your boat....so you don't have to be dealing with mechanics whose language you do not speak.
I'll stop there before I start crying again.
