1 - 13 of 13 Posts
We have just fitted furlers to our genoa and stays''l. Several sailors have said "Oh no - jamming is a real problem." Any comments on the risk of jamming versus the risks in going out on the bowsprit to change sails please?
When I look at those boats with long bowsprits I get the chills. I really like roller furling/reefing.
Like any tool they work best when used right. One of the biggest causes of jams is cobbling caused by not enough tension on the line as the sail is rolled out.
Tell me what kind of furler/reefer that you have an on what boat?
Discussion Starter · #3 ·
MikeMoss - thanks for your response - my feelings exactly. We have a classic wooden cutter - see pic on our page. She has a long bowsprit.
The genoa is about 115% and the stays''l also a reasonable size. We particularly like the stays''l if it gets rough and choppy - the genoa is really a lighter weather sail.
The furlers are Profurl (B29 Long and B29 Short models) and seem to be beautifully made - we installed them ourselves so we really know how they work. The only problem we have had is when we didn''t tighten the halyard enough and the halyard itself got around the wrapstop at the top. That solved, we haven''t had another problem. I haven''t got the exact details from others about how the jams they experienced or heard about occurred.
I''m also a bit surprised to see so many of them about on cruisers and even offshore racers, if they cause so much trouble.
Our experience (only used them 6 times so far) has been GREAT. Huge confidence boost in the strong onshore breezes we get here.
i am searching for a torque link for an old ''Stream Stay'' K2 roller furler. one link holds each of the 5 sections of the aluminum furler in alignment with its neighbors. the link is a stainless pin with a delrin bushing.One broken link makes the entire roller furler unusable as the topmost section will not stay in alignment to the lower section and the sail twists and won''t unfurl. Does Any one have any sources for this old part ??
I hear the Profurl is top of the line. I have a Schaefer 2100 on a C&C 35-1 and it works really well for furling and I use it to reef sails as large as 150% will great success.
A tangle at the head can also be cause by too vertical of a halyard position. The Schaefer offers a deflecting plate to force the halyard into a greater angle from the forestay.
Enjoy
I hear the Profurl is top of the line. I have a Schaefer 2100 on a C&C 35-1 and it works really well for furling and I use it to reef sails as large as 150% with great success.
Enjoy
Discussion Starter · #7 ·
Thanks MikeMoss - I''m not sure I understand what you mean by the deflecting plate . . .
Is it like the wrapstop arrangement - a small circular fitting over the top of the furler tube with a cutout on the side nearest the mast to catch the halyard?
I think our furlers are at the right angle - in fact we have tightened the genoa one about 10mm and it now winds up more precisely and doesn''t swing about. Can''t have it too tight on a wooden mast.
I also have Hyde Streamstay furler. A company in New Jersey still sells all the parts. I have the info but itis on my boat under cover for the winter. They do advertise in sailing mag. If you don''t find them by early april email me and I will have the info off the boat.
The part i am searching for is for the Stream Stay systems roller furler ''K2 sectional system'' with 1.07 inch diameter foil extrusion. This roller furler was in excess of $1800 , and was formerly sold and manufactured out of bristol, RI. the dealer, Rig Rite, Warwick RI had promised me this part 2 years ago and still '' cannot get it'' from the manufacturer.. Rigrite tells me I should consider purchasing an entire new roller furler, when what I lack is a $17 ''torque link'' or ''connecting tube.''
StreamStay Roller Furler
Hi, I am looking for a manual and/or parts list for a StreamStay Roller Furler. Also I need a feed guide for one.
I also have a spare unit and might have some spare parts (other than the feed quide) for anyone intrested.
Does anyone know if the manufacture or any stocking parts dealers still out there?
Regards - Gene
Hello Doug,reference...Streamstay Furler
Hello! I just purchased a 1971 Morgan 30,and it has a broken section at the bottom where the sail feeds into it.I am hoping to purchase just that part.You had mentioned tht there is a company in New Jersey that still carries parts for that system.Would you mind sending their name and location and possible e-mail address?Thanks ahead of time...Ray Ball
That was posted in 2001 so you might not hear from him. I don't know of anybody in NJ but Rig-Rite in RI had parts as of a few months ago so try them.
www.rigrite.com
Kim doesn't do e-mail and the phone is questionable so try faxing.
All the best,
Robert Gainer
1 - 13 of 13 Posts
