1 - 5 of 5 Posts
Hi All,
I've installed my new Signet Marine classic sailing instruments. All I have left to do is wire 12V for the red lights. I was just going to wire them to the switch breaker for running lights (as is the compass light). Should I wire them in series or parallel? Does it matter?
Dave
Mermaid Hunter
If you can find space I'd wire instrument lights and compass light on their own individual breakers. If you are using electronic navigation the data will be available on your chartplotter and the instruments and compass light are just more light in the cockpit. You may well find the chartplotter backlight, even turned way down, is adequate for reading the instruments.
Keeping night vision attuned should be a priority. That means minimum light sources in the cockpit.
Sea Sprite 23 #110 (20)
I would consider adding a "dimmer" too Some nights can be darker than others due to position of the moon or ambient light pollution, so having some method to changing the amount of illumination could be good
1 - 5 of 5 Posts
