I have a 44' ketch I intend to sail offshore, and currently I have no provision for staysail sheeting. The staysail lead will most likely run on the lower deck inside of the genoa lead (toerail), which makes for a straight shot back to the primary winches. My idea is to run both the genoa and staysail sheets through clutches so the primary winches can be used for both genoa and staysail. The other option is to add another set of winches for the staysail, which for my boat would be difficult.
Is anyone else using this type of shared winch arrangement on a cutter rig? How has it worked out?
