1 - 4 of 4 Posts
Not Finished Yet
Discussion Starter #1
Our arrangement is deeply unsatisfactory and needs to be changed. Anyone have pictures of their system? Especially features you are really happy with?
I don't really care what kind of anchor you have, this is more about the system and the method of deployment/retrieval.
We have a SeaTiger, but for some reason has no hole in the deck for the chain to drop down. Makes retrieval a major PITA. There is a hawse on the rope side of the windlass, but a good 18 inches from the windlass.
Wandering Aimlessly
PBzeer Gallery - My Photo Gallery
My locker lid was delaminated when I bought the boat. There was a stainless steel plate across where the windlass is. I fabricated a solid piece of fiberglass to replace the SS, and then recored the rest of the lid. Then screwed a piece of starboard with a slot to hold the second anchor.
Raindog,
We have a Muir vertical manual windlass (Australia). It works like a sheet winch on the retrieval, but has a clutch for dropping. Lots of leverage and speed. I can crank our 3/8" chain in as fast as most electrics without the worry of motor or electrical failure (I've won bets on this twice). It sits on a piece of teak that is molded to direct the chain down the hawse pipe with no hangups going or coming. The pipe is a 2-1/2" bronze through hull fitting. This lash-up works very smoothly and has done so for seven years.
Pictures are at Outfitting6Solar (bottom of page) and here, Outfitting2
After these pictures, I installed a chain stopper forward of the windlass. Picture here, OutfittingFinal
After you click on the thumbnail for these pictures, click on the actual picture and it will enlarge again.
Let me know if you need closer pictures.
Dave Mancini
PSC34 #305 Swan
Learning the HARD way...
I posted this in another thread;
Several people have asked me about my ground tackle setup, so I thought that I would post this here to explain what it is, and how I use it.
Below is a diagram of how I would deploy the anchor if I needed the greatest holding power (storm).
The optional 10' of 1/2" chain weighs about 34lbs, and acts like a kellet, except that it will not chafe the nylon anchor rode. To be honest, I have not had the need to use it in the 3 years that I have hade the boat, and am afraid of having to haul it up with the two arm windlass. The windlass is getting old and creaky...
The usual setup is to deploy the 33lb Rocna on 25' of 5/16" HT chain.
You'll notice that the retrieval line is tied, with a float to the thimble at the end of the 5/8" nylon rode. The float keeps the lightweight line from getting tangled on the bottom, and should the nylon line ever be cut, it would make retrieval easier. I believe that I have a better chance of catching this with a grappling hook. Because I don't usually anchor in more than 30' of water, if I untie the line from the thimble, it would act as an anchor marker.
I tried the anchor a couple of times without the retrieval line. I found that it was hard to break free, and it hauled up about 15 lbs of bottom. Now that I use the retrieval line, the anchor breaks free MUCH easier, and it only brings up about 5lb of muck.
Ya' it's a Chinese made Rocna; but it works fine, fits my bow roller, and sets right every time.
Here are two pictures showing how it fits on the bow;
I use the retrieval line as a safety, in addition to a stainless steel carabiner hooked to the Rocna's rollbar, to keep the anchor secure on the bow roller.
I'm putting this here for my benefit, but if it helps someone else, you're welcome. :)
Craig Smith commented that he believed that I would have better holding power if I moved the heavier chain nearer the anchor. I disagreed, and he never replied. You can read all about it here:http://www.sailnet.com/forums/gear-maintenance/100243-ground-tackle-oday-35-a.html
1 - 4 of 4 Posts
