1 - 6 of 6 Posts
I was wondering if anyone has worked on the shower drain for the endeavor 33. It seems to have a breaker on the electrical panel, but I have not been able to find the pump, switch or where the shower drains. HELP!
Thanks
Joel
Can anyone comment on where their shower drain drains to? On my newly acquired E32 it is plumbed to drain into the main bilge which I am not a big fan of. I was thinking of a secondary containment smaller tub to drain to and then pump out from there.
Thanks, Cal
s/v Agave Illusion
1981 32 Endeavour
Cal on my 79 E-32 the shower is pumped overboard. The thru-hull is located under the transom.
MarioG - Thanks for the info. In mine there is a secondary diaphram pump T'd into the bilge pump line which all leads to a thru hull under the transom. I'd like to keep the bilge pump line a dedicated line so I may look to pump the shower through one of the thru hulls forward near the head area. I need to examine the thru hulls there to see what is plumbed where....some many projects, I just want to get in the water and get sailing - Cal
1 - 6 of 6 Posts
