...there is some kind of force plate in the deck? I think I would rather have chainplates and turnbuckles,...
I looked up some pictures, and it looks like Beneteau has moved the tensioning system below the deck to make a cleaner look above deck. That sounds like a pretty good idea.
It seems pretty simple, and actually pretty ingenious. The cable shroud disappears through a small waterproof grommet in the deck and is attached somehow below. That puts all of the hardware below deck, where it is protected from weather and corrosion. One picture I saw shows an access panel with screws that looks like it can be easily removed for rig tuning.
Beneteau may have come up with something new and Innovative, that is an improvement over the old turnbuckle-above-deck system. I don't think I would want to change their system. I bet Beneteau has technical advisers that would tell you. You can probably buy the shrouds from Beneteau, very likely at a much higher cost than regular shrouds from a rigging manufacturer. But new mechanical Innovations, are often a dealer only item, until they are adopted by other manufacturers.
I imagine that the first production car to have disc brakes, was probably some expensive luxury car, and they could only be serviced by the dealer, until they came into widespread use in other cars.
If it's a 1993 model, that means that the system has been in use for at least 27 years. Maybe there are certain rigging companies that know how to make replacement shrouds for Beneteaus with this system. Beneteau could probably direct you to a rigging specialist in your area.
