Please share your single-handed tips and tricks which make sailing easier, more relaxing, more efficient and/or safer for those of us who enjoy the freedom of sailing alone.
I'll start things off.
This isn't rocket science, but it's something I've developed out of routine and not something I heard or learned from someone else, though it may me practiced by many already.
When sailing alone in an area that requires short tacks, I've devised a way to limit scrambling from side to side, around the wheel in the cockpit.
After completing a tack, and once satisfied with the trim of the head sail, I remove the winch handle and form a "double-back" loop in the reverse direction around the winch and bring the tail back to the helm. Then I step to the high side, pre-load the empty winch and pop in the handle, again leading that tail back to the helm.
When I get to the next tack point, I simply give the sheet a quick tug to free the line from the self-tailing jaws, then hold the sheet tail high and "un-lasso" the line off one winch and haul the other sheet tight, without having to leave the helm position. Then I repeat the procedure in preparation for the next tack.
It doesn't sound like much, but prior to using the "double-back" loop on the loaded winch, I had to crawl to the low side a second time to "unwind" the sheet from the winch jaws, which was not only hard on the knees, but depending on wind strength, could get tiring on a long beat if the boat is healed hard.
I always "double-back" now. It has changed the way I sail alone.
