Any recommendations for a single-lever, dual-action, side-mounted, flush-mounted (cables attach behind the lever on the opposite side of the surface to which the controls are mounted) control for a 1987 Johnson 8HP Sailmaster on a 26' Pearson? My old one seized. I removed it, and it was mounted on/through a 2" diameter circular hole. I've found a couple that LOOK like they'd work, but can't find enough information about the mountings.
Uflex B85
Vetus SISCO or SICO
Teleflex CH2100P
The Teleflex is described as a "Surface Mount" which makes it sound as if the cables would be exposed in the cockpit, and I don't want to do that. Is that the case? I can't find any mounting info on the other ones. It'd be GREAT to find one that mounts in the same 2" hole, but that may be a pipe dream...
Anyone have any experience with any of these, or able to make other recommendations?
Thanks..
Barry
Uflex B85
Vetus SISCO or SICO
Teleflex CH2100P
Thanks..
Barry
