1 - 16 of 16 Posts
Hey everyone,
I have an odd problem that I hope you can help me with.
My sink in the galley has acquired an odd / bad smell.
I've cleaned the sink bowl and run boiling hot soapy water down but it won't go away .
I worry about putting bleach down there as I don't want to damage the pipes.
The boat was built in 2008, so I doubt the pipes need replacing. There is no smell below he sink area or in he heads sink or head Itself.
Many thx in advance
Chuck buck
Maple leaf
Ben 31
Hi everyone
Any suggestions on how to remove Oder from the sink in the galley?
Much appreciated!!
Old as Dirt!
Hey everyone,
Many thx in advance
Chuck buck
Maple leaf
Ben 31
Hi everyone
Much appreciated!!
Floating debris rotting on the water surface within the drain, including, perhaps dead sealife. One solution is to "blow" the standing water and its contents out. For that you can use one of the pressurized signaling horns sold at marine stores. You can make a temporary gasket around the drain with a couple of wet paper towels cut away over the drain opening itself. Press the bell of the signal horn down, over the drain, firmly and give the drain a 2-3 second blast. The pressure will blow the standing water out through the through-hull. If the drain serves two sinks, insert a plug in one and hold it firmly in place while blasting out through the second/adjoining drain. We've used the foregoing to good advantage in past...
Don't call me a "senior"!
Pour a cup of bleach down the drain, let it sit five minutes, and then pour a bucket of freshwater down the drain (or stop up the sink and fill it with the house water, then pull the plug) to flush out the bleach. Five minutes of bleach isn't going to do anything appreciable to the pipes. And a cup of bleach isn't going to do anything appreciable to the environment. Also, try to "flush" the sink (either with a bucket of water, or by stopping and filling the sink) every once in a while to prevent a reoccurrence.
Reactions: christian.hess
Occasional use of bleach is not doing to harm anything.
Something that is often misunderstood about bleach is that more is not much better, but it can be more destructive. The more that is used, the higher the pH, and the less the germicidal effectiveness (broad statement with many limitations). Time is much more important. This holds true for many cleaning applications; less bleach and more time.
Mix ~ 1 tsp/gallon and let it sit in each of the drains for at least an hour.
But you might try this first, to remove the junk: baking soda followed by bleach. At first I thought this was silly; just a bunch of CO2 from the reaction. But it is the bubbles getting UNDER the dirt that does the work in inaccessible places, combined with the initial alkalinity and surfactant nature of the bicarb.
Clean Your Drains With Baking Soda and Vinegar - Surprise! | Crunchy Betty
Corsair 24
bleach
I like the fog horn or pressure blow idea too...saves you from going over and manual degunking the thruhull
I do the bleach thing here at the house every week or so since we use cisterns for half the day when the water is cutoff for the city we live in
guess what? same funky smell you get on boats. you let bleach sit for 5-10 minutes then flush and rinse and you can see it get completely gunk and smell free...
simple
Sailor of Small Waters
They are right about the bleach, and about using it sparingly.
If you are concerned about the bleach you can also use hydrogen peroxide to kill smells and it is harmless to most pipes and such, as well as wildlife, etc. You want to use the standard drugstore 30% active type, use generously, and let it sit for a little while. It's not quite as aggressive as bleach, so you may have to repeat.
Trust me, I'm an R&D chemist for a company that makes cleaning supplies and deodorizers...
The "standard drugstore" hydrogen peroxide is 3%, not 30% H2O2 in an aqueous solution. However, you can get ~30% hydrogen peroxide that is marketed as a "cleaning solution" (rather than as a topical antiseptic) at some hardware stores, hydroponics supply outlets, aquarium shops, etc. Strong solutions will burn the skin, and are probably about as dangerous as household bleach. Industrial grade peroxides (including >30% hydrogen peroxide) can be downright nasty to use, and should be avoided unless you have some experience with such chemicals.
I would just used regular bleach; it's quick, easy to get, and cheap. But the ultimate source of the problem is organics floating inside of the sink drain plumbing. A little bit of cooking oil, some food scraps, and whatever else doesn't get flushed out will turn into a stinky brew. Many (most?) boat freshwater systems don't deliver water at a high enough rate to effectively flush that gunk down the hose and out the thru-hull. That's why I suggested pouring a bucket of water down the drain once in a while. You might also try scrubbing the inside of the hose with a long-handled bottlebrush to remove any mold/mildew growing in there.
Master Mariner
If it's just "A little bit of cooking oil, some food scraps, and whatever else" what's wrong with using a plunger? It's an awfully good test of your hose connections and clamps, but other than that, it should blow anything in the drain, out.
If the plunger will force enough air through the plumbing to displace all the liquid, then it would probably work just fine. The trick is to get everything past the thru-hull. If there isn't an actual clog then the plunger shouldn't really be "pressure-testing" anything (as long as the seacock is open).
DON'T POUR BOILING WATER DOWN YOUR BOAT SINK.
Close the through-hull if there is one, flood the pipes with vinegar. Let it sit for a day or more, then flush it out.
I have this problem because people always pour the last sips of beer or alcohol (I know, it's a crime in itself) down the drain and alcohol will stink it up. Vinegar wipes it all away.
Vinegar. Keep it on board!
If youve been draining fats and oils down the sink drain these will be trapped above the waterline (similar to a 'grease trap' in a sanitary drain) and adhere/congeal to the hosing, etc. What happens next is the proteins begin to rot and 'putrify' ... forming 'putrenes', the unpleasant odor of decomposition.
To remove, close the through-hull and pour in STRONG caustic detergent (TriSodiumPhosphate {TSP} or lye based soaps are also good) and let soak to dissolve the fats/oils and their rotting 'fragrances'. You may have to repeat the soaking a few times to thoroughly remove the 'stink'.
Once cleaned out, simply dont pour fats (bacon grease, etc.) down the sink drain, pour these into containers, seal them and put them in the trash.
Holy crap! I totally fat-fingered that! PLEASE don't use 30%, you are right retail is 3%.
Did I say trust me? LOL. Sorry. TGIF.
S/V Wyndwitch - Morgan 24
Thanks for the air horn technique...very appealing. Done properly quite useful After a bleach soak and timed properly it could render unsociable noisome effects :)
I use a mild bleach+soap solution on all catchment areas in the boat... just a spritz here and there does it.
Administrator
Beneteau 393
Actually you will find bleach about 6% Sodium Hyperchlorite.
http://www.thecloroxcompany.com/downloads/msds/bleach/cloroxregularbleach0809_.pdf
It seems to vary country to country probably because of local laws.
Bleach is your friend on a boat.
As a test get a jar and put in a piece of water hose, an old Jabsco toilet O Ring and any bits of rubber or plastic that lying around the boat and fill it with normal household bleach, like Chlorox, at full strength.
Watch it CAREFULLY for the first hour.... Now keep watching for a whole week and test the rubber and plastic used in toilets and water systems on boats...
It will come out clean and undamaged. The rubber wont be sticky, the plastic will still be fine...
After that you will feel fine to use bleach all over your boat.
Splash it around! It wont hurt your boat, it will not hurt the environment.
(Love the air horn idea!)
Mark
1 - 16 of 16 Posts
