I've decided to get rid of my propane fridge and put in an Engel dop-in 12v model:
https://www.engel-usa.com/products/...n-models/engel-mb40-drop-in-remote-compressor
I believe it will use between 24 and 50 amps per day, depending on the ambient temperature and whether I run it as a fridge or freezer. I currently generate all my energy needs with two 45w panels and store it in one big 160a battery (I have a 70a cranking battery as well). I realize I'll have to upgrade my energy system with the new fridge. I can fit one big 240w panel over my bimini (fixed between the hard dodger and the arch) or two 100w panels. The price per watt is much cheaper with the big 240w panel. I would also upgrade my battery bank to one 220a battery. MMy energy use is low (all LED, tiller pilot on windvane, manual everything) so I should have a daily energy requirement of about 50 or 60 amps tops. I like keeping things simple. My questions are:
Will I have enough solar panels (total 330w) to reliably meet my energy needs?
Is there any disadvantage to using one big solar panel instead of two smaller ones?
Will my house battery bank of one 220a deep-cycle battery be enough? Batteries are expensive here and, unfortunately, we can't get the 6v golf cart batteries that are so popular in the US.
If anyone has any suggestions or advice, I'd be grateful. I suppose I will also upgrade to a better solar controller as well. Thanks in advance!
