I don't think Renogy is in the same class as Kyocera. From the Renogy Warranty download:
http://renogy.com/wp-content/uploads/2014/04/Warranty-off-grid-kits.pdf
"LIMITED WARR
ATNY: Renogy warrants this product will be free from defects in
The warranty does not cover failures result from ...natural elements, ..."
Yes, we all make typos (Warratny ?!) but a real grown-up business sends that stuff past legal and engineering and other people and multiple eyes have to fail to read it. Typos on an important legal document like the warranty mean it isn't a very established business "yet".
The warranty also excludes damage due to natural elements, which would mean rain and salt water spray. So, there's no warranty for exterior or shipboard use. That's even better than the companies that exclude "use on moving vehicles" and boats.
Coming back to the numbers...
"I believe it will use between 24 and 50 amps per day, "
Let's say that's 50, and it would be 50
Amp-hours not amps. It would be important to know if that's at 12.6 volts (battery power) or 14.4 volts (alternator power) since the overall wattage pulled will be different. Split the difference and let's say 50 AH at 12.6 volts for a nearly full battery...
"...one big 160a battery ...I would also upgrade my battery bank to one 220a battery."
" I should have a daily energy requirement of about 50 or 60 amps tops." 10AH for everything else seems conservative, but if you have LED nav and cabin lights, or no night lights, it might be.
"Will I have enough solar panels (total 330w) to reliably meet my energy needs? "
If you are using an MPPT controller, you will get about 15% more power out of the panels than any other kind of controller. That is, an MPPT controller will give you almost the full rated power at battery voltage (330W at 12.8 volts, about 25 Amps) and depending on installation angle, time of the year, how far off the equator you are, you can count on that for the equivalent of about 5 hours per sunny day. So, about 125 Amp-hours per day from the solar panel. Without the MPPT controller, possibly 15-20% less power because other controllers throw out the excess voltage from a solar panel, which might be 17-22 volts for a nominal "12" volt system. Even if you didn't use MPPT you'd probably see 100Ah per day, which would be "enough" but give you less of a safety margin.
If you're making 125 Amp-hours and consuming 60Ah, you'll have plenty of power. I'd even suggest keeping the 160Ah battery as long as it is in good condition, and not replacing it until it weakens or there's some other good reason.
Assuming, of course, I've gotten my math right, which doesn't always happen.
