Ive been refinishing the sole boards on my moody. i'm on the final coat of the last three boards... its been a very nice and rewarding project...
Final coat. Two different cans of helmsman. Both clear satin. Same roller. Same prep. Same conditions. Cans came out of the same batch from the factory. The new can is on the left. Old can on the right. Cans were purchased a few days apart. Work was done at 8pm last night. So about 10 hours
Dry to touch no tack
i know I should have blended the two cans together, but they came out of the same batch from the factory so I figured i was good to roll on...
started right worked to the left, and then on to the next panel.
you can see where i changed cans.
I could see if I had done two different panels at different times using different tools
obviously something about the two cans is the culprit... i was hoping to put them back down this weekend...
I'm going to try some de glosser and scotch brite pad, or may be 500 wet to see if I can get the finish back to satin...
worst part is that the ladder was also done with this can and it just as glossy. and it was a PITA to get a nice level no run coat...
