1 - 12 of 12 Posts
Break, curse, fix, repeat
For anyone else out there with a diesel that runs too cool, especially a Universal 5432, I am happy to report that I have solved this sort of problem on Aeolus. In short, the factory thermostat is rated 160, which as many will know is fine if you are raw water cooled to prevent salt crystals forming, but for those many of us with fresh water cooling, 160 is way too cool. This can dramatically shorten engine life and produces carbon build up in the usual places.
The engine manual says the optimum temperature is 170-185 and yet Universal only provides a 160 thermostat. Go figure. Without giving a dissertation on the things that influence engine temperature, suffice to say here that Aeolus ran a steady 160 no matter how hard she was run, and that this was controlled entirely by the 160 thermostat setting in my case. She has an extremely efficient cooling system.
After a lengthy search involving all the usual steps, I found my answer. Car Quest makes a 180 and 195 degree thermostat that is an exact match. They are actually made by Stant and just rebranded by Car Quest. I put the 195 degree in Aeolus tonight and ran her up to temperature and she parked herself on 190!!! Perfect. :)
Car Quest part number 31979
I could just see the carbon burning off the piston rings and the valves. In my case this is especially important because I run a high % biodiesel for all the mechanical and environmental benefits, and it has a slightly higher flash point which is helped by the higher operating temperature.
As only someone who really knows their boat can appreciate, I noticed a distinctly quieter and smoother sound to her tonight while running at the higher 190 temperature.
For pictures and more of the story see my boat blog at Stories of Aeolus- Our Gulf 32 Pilothouse
I hope this helps anyone else out there who has an efficient cooling system and who worries about carbon build up with an engine that is running too cool.
Hey, that is great info. Very nice of you to share it.
One question: If the manual states optimal operating temp is 170-185, why did you decide to go with the 190 thermostat when a 180 was available?
Okay, one more: Do you have the part no. for the 180 thermostat available?
Discussion Starter · #3 ·
Hi John,
I'm glad you think this information is helpful and I truly hope it is. The only reason I post and do a blog is because I myself have spent so much time trying to learn from other people and feel I should do my part.
I am using the 195 degree for now because even with that she runs a steady 190 degrees. From all I can read this is well within the safe margin for continuous operation and I am hoping to burn off any accumulated carbon that might be removable. As long as she stays around 190, I see no reason to change. Again, between our 45 degree water and my efficient cooling system, there is virtually no cause for concern about overheating as she never budged above 160 before.
I suspect that with the 180 degree thermostat that she would run between 175 and 180, which is at the lower limit of fine, but after her being run 700+ hours too low in temperature, I am anxious to run her at the upper margin of things.
The CarQuest part # for the 180 thermostat is: 31978
Hope this helps.
I doubtable that with the 180 amount thermostat that she would run amid 175 and 180, which is at the lower absolute of fine, but afterwards her getting run 700+ hours too low in temperature, I am afraid to run her at the high allowance of things.
_________________
Thermostat
The hole(s) are there to allow air to escape when filling the cooling system.
Without the holes the engine could overheat because the traped air under the thermostat will not heat the element enuff for it to open untill the engine is over heated and then if it does open it will allow cold water to hit the hot engine parts, not so good.
I imagine a sea water cooled engine would have this problem every time it is started.
If you don't have a hole in your thermostat I think you should drill a small pin hole in it.
bwindrope: picked up on your old thread and thanks. Not sure if you are still out there but did you ever get a good answer as to why a 160F thermostat was used in the application for the 5432? The Kubota thermostat that lines up with my block is clearly a 180F thermostat from OEM. I read you stated something about salt crystals in an open loop application. If you are still out there and have any feedback it is appreciated. Thanks
Discussion Starter · #9 ·
Hi westerml, I'm still around once in a while. Sorry though, I don't have any insights into why the 160 was standard on my vessel. Sounds like you found OEM to be warmer. I think at the time I was consulting with Cook Engines in Portland, Oregon a Universal and Westerbeke dealer and got that information. In any case, all that matters is that we run our diesels at the appropriate temperature, which depending on our cooling systems and local waters may require different thermostats. All I have ever read and learned tells me that diesels don't like to run cool, and so I err on the warm side within specifications.
I can update my story to say after running the 195 for several years, I decided to drop down to a 180 and have been happy with it. She runs a steady 180 to 185, and I feel good about having done whatever good I could to burn off any residual carbon and such from the earlier years of running way too cold.
Good luck with your engine! Those darn things are our masters, and we their servants.
Most internal combustion engines run most efficiently with a cylinder wall temp of 190-200*f. Lower and you get incomplete burn and carbon build up, higher and you start producing oxides of nitrogen and slowly burn it up.
A real quality thermostat does it with a jiggle pin, so coolant doesn't flow through the open hole.
1 - 12 of 12 Posts
