The 'downhaul' setup you describe has the advantage of not needing adjustment for pole fore/aft as you've noted.. and it also works well with on-the-boom pole storage setups.
What it doesn't do so well is immobilize the pole end, as you've noted, esp in allowing the pole jaw to slide aft on the guy on occasion, destabilizing the tack.
The easiest fix to prompt the pole to stay at the end of the guy is to twing the guy down to the deck edge amidships.. this forces the pole out to the end of the guy. This is a relatively simple bit of rigging, and easy to use, simply release upon gybing and set/twing the 'new' guy.
Laser 28s have always used the mast pinned 'downhaul'.. and twingers.
