Is my starter motor playing up or my start battery dying?
1) My starter was reconditioned about 2 years ago.
2) My battery is 90 amp starter battery approaching 3 years old. It gets a trickle charge from my solar panel and the Battman volt meter reads 12.7, when I get on board before starting the boat. The solar panel was installed about 12 months ago, until then the battery only got a charge under motoring.
Symptom:
Unpredictable cranking strength. For the last 6 weeks, normal strength cranking to barely turning. Yesterday...when the engine was warm after about 15 minutes running, I turned it off and only got a click of the solenoid, when I tried an almost immediate restart. Hit the button again and she JUST turned over enough to start. Ten minutes later I tried the cycle again and it started perfectly.
Any thoughts or advice?
Thanks in advance.
GF
Symptom:
Thanks in advance.
GF
